Ok, I'm a cheap bastard, but I couldn't pass on the opportunity to get a dyno run at a local bike night for $20. (actually won $50 because there was nobody else in my "class", so I'm $30 up + plus some knowledge gained). Unfortunately they didn't run an O2 sensor, so I'm not sure what is going on. The guy running the machine said that I should raise the needles up a notch, but when I did, I barely made it back home on the test ride. Is there any obvious adjustment for the RPM range where I have the dip? The current setup is: K&N in factory airbox, adventurer ORs, 100 mains, factory pro needles on center notch, 40 pilots, AI screws 2.25 turns out. Any comments/suggestions would be appreciated.
