Old 07-27-2006   #1 (permalink)
If my memory is right I did read somewhere that the some Tokico calipers would be a fit on TBS forks. Did some searching but could not find which one.
Anybody know which one I should be looking for.
In doubt, crank the throttle.
Saigon5 is offline   Reply With Quote
Old 07-27-2006   #2 (permalink)
I know they will bolt on the Daytona 900/S3 forks, but not sure about regular TBS forks as the rotors are different.
2000 TBS Cafe Racer :: 2000 Frankenmille
TBSstunta is offline   Reply With Quote
Old 07-27-2006   #3 (permalink)
Favorite Bike: Well, Duh!
MickMaguire's Avatar
None that I know of unless you make custom brackets then you can fit anything. The bolt hole spacing is different on the Tokico calipers and the Nissins that are used on the TBS.
I wonder if you are getting confused with the fact that tok 6 pots will fit the Trophy, T3 Sprint and Daytona. Or perhaps its because I have tok 6 pots on my bird (but I have ZRX forks and wheels)?
[ This message was edited by: MickMaguire on 2006-07-27 06:21 ]
Mick...
Old 07-27-2006   #4 (permalink)
Could very well be that I am confused indeed. May be I read too many post.
Actually, it was more for an eye pleasing reason than more braking so it is not that bad. I have enough brackets as it is.
Thank you
Brake upgrade PhxMan Sprint Forum 3 12-02-2007 11:21 AM
Brake upgrade the1mavin T3 Sport / Touring Forum 2 09-13-2007 10:18 PM
brake upgrade ricster Sprint Forum 1 04-05-2007 03:45 PM
Brake Upgrade ufosprint Sprint Forum 1 03-04-2007 01:07 AM
Brake upgrade HiDesert Biker Hang-Out 3 01-16-2007 05:40 AM
