Yes I understand that part ,but would a air filter at the end of its life cause a higher vacuum reading than a brand new oem filter that is the question
Assuming that the filter is partially clogged it will decrease the absolute pressure (referenced to open air) at the inlet to the carbs.
Since this is a series circuit from the filter inlet to the engine it will also decrease the absolute pressure at the outlet of the carbs, but unless the filter is nearly plugged solid it will only have a minor effect on the absolute pressure at the carb outlet.
Jim
