Looking to get a rebuild kit for my 97 thunderbird-I have called around and keep getting pointed back to the dealership. Is this the only option? Thanks for your help.
I'm pretty sure no one makes a kit. Unless you need a new inlet needle and seat (unlikely) there is not that much to replace. A few o-rings and the bowl gasket is about it.
As long as you have a Haynes or Triumph manual, you should be OK.
are the o-rings and float bowl gasket acquired from the dealership? are they individual parts or do they have an o-ring/gasket carb package? Thanks for your help...can't wait to get it back on the road again.
Individual parts.
You could probably source the o-rings elsewhere but you would need to know all the sizes. Probably best to get them from the dealer. They shouldn't be too expensive.
