Thanks for all the input. Hears some pictures to illustrate the wear.
Its not that clear from the pictures, but i think the wear is too far over to be riding position.
The rear tyre has normal wear and i think its as central as i could hope for.
Again the camber theory might explain some wear just off centre.
The forks are the same in the yokes and they measure the some length when stood together.
The wheel is about half a millimetre to the left (sat on bike).
I bought the forks on ebay and was wondering weather the springs are shot or uneven. Also i has to change one of the fork legs as the compression adjuster was knacked. There couldn't be a difference in the fork legs could there?
Or it maybe that I'm just more aggressive on right turns and bends than left!
