AdvanstarMotorcycleShowsTrident-Exhausts.comMotorcycle.com
Old 07-15-2006   #1 (permalink)
Have any of you guy's ever had any problems with the rear shock leaking, It seems to be leaking and it bottoms out . Can they be rebuilt or if any one has replaced it can you go aftermarket?
Thanks Mike
mdbauer is offline   Reply With Quote
Old 07-15-2006   #2 (permalink)
Favorite Bike: '98 Thunderbird Sport - Buford
denny's Avatar
Other Motorcycle: '96 Thunderbird - Bessie
Extra Motorcycle: Anything that runs
popular replacements are by Hagon. More expensive ones by Penske and Ohlins.
Cheers,Denny
denny is online now   Reply With Quote
Old 07-15-2006   #3 (permalink)
Tre900's Avatar
I replaced mine with a Hagon that I bought from "David Quinn". There's a link on the top of this page from time to time. You might have to refresh to see it.
I totally recommend it but keep in mind that in order to change it yourself you will also want a torque wrench to adjust the correct NM on the Suspension bolts. If you don't own a torque wrench be sure to get the one that goes up to 250 ft/lbs. I foget the actual nm (ft/lbs) it is but it was a lot. Its an expensive replacement but if you do it yourself you save a little AND you can then adjust and rebuild it in the future if need be.
_
(_)=='(_) "..Get your motor ruuunin'..."
Tre900 is offline   Reply With Quote
Old 07-16-2006   #4 (permalink)
Tre900,
Thanks for your information, I looked up the information Is the Hagon shock better then the OEM from Triumph.
And you said that the Hagon is rebuild-able?
Thanks for your help.
Mike
Old 07-17-2006   #5 (permalink)
Favorite Bike: Well, Duh!
MickMaguire's Avatar
Most people like the Hagon better than the OEM, you'll like the price difference too. The OEM shocks (apart from the tBS item) are pretty poor.
Personally I was put off the hagon a bit as they are made in the old Girling facotry in the UK. Girling didnt have the best reputation for shocks years ago. But this is purely prejudice on my part.
[ This message was edited by: MickMaguire on 2006-07-17 06:58 ]
Mick...
Old 07-17-2006   #6 (permalink)
Tre900's Avatar
My thought is that this shock is better AND the spring is red, it looks super cool!!
_
Old 07-18-2006   #7 (permalink)
Thanks for the information , I ordered the Hagon.
Thanks for the help
Mike
Old 07-18-2006   #8 (permalink)
Put a Hagon on my 01 T-bird two months ago. What a difference. Night and day. It really brings out the beauty of the T-bird.
If you decide to get a Hagon be prepared. You will have to call Dave Quinn. He will have a battery of questions for you. Block out some time for the call. This is not a this is what I need and here is my card# call. Plan on a complete questioning of your riding. He then sets the shock up. Then it arrives. You install it. And heaven.
I have a set of Hagon springs on order from Dave. Will let you know how those work out
JR
Guttermonkey is offline   Reply With Quote
Old 07-19-2006   #9 (permalink)
Thanks guy's you were right the new Hagon shock. It was larger then the OEM shockI pulled off the bike last night and I road it to work today, Man what a difference. I can't thank you guy's enough for the advice...My Adventurer is an adventure to ride.
Thanks again,
Mike
[ This message was edited by: mdbauer on 2006-07-19 04:13 ]
Old 07-19-2006   #10 (permalink)
Tre900's Avatar
Yeah dude, I was blown away by the change it made in my bike.
After that I got a Corbin and "forget about it"!!! Never need another bike for solo riding.
_
Rear shock ? gordong65 T3 Sport / Touring Forum 10 03-25-2008 07:39 PM
New rear shock mick-f Sprint Forum 5 11-21-2007 01:36 PM
Rear shock Chadillac Hinckley Classic Triples 12 03-08-2007 09:47 PM
Rear Shock tbirdtroy Hinckley Classic Triples 8 10-09-2005 12:43 AM
rear shock bobh Trophy 7 09-10-2005 09:22 PM
