I have read numerous comments about rough running engines. Here is my situation!
1995 Tbird, 50k miles. It's been a great bike, and very reliable. Now I have a problem, where the engine stutters (sometimes stalls) when starting from a stop, low RPMs. The problem comes and goes (even on the same short ride). The engine starts easy. Revving it in neutral seems ok. And once it gets moving and the RPMs are above 2500, no problems at. All the power seems to be there once I get moving and need to accelerate. It is not clear to me that the problem is related to cold versus hot.
I followed some suggestions and looked at the coils and spark plug wires with a timing light and ohm meter, and did not detect a problem. I have the original coils on this bike.
I put an inline fuel filter on my bike years ago, so I do not suspect dirt in the carbs.
I did back out the idle mixture screws on my Mikuni's a month ago to get rid of decel popping. That procedure went well, with no problems. Engine ran great and decel popping almost eliminated. Note I was surprised that the screws were all the way in from the factory for all three carbs. I backed them out 2.5 turns. The bike was running fine for a month, and now this recent problem arises. So I do not think the problem is related to the mixture screws.
Any advice!
