On 2006-07-05 11:46, Ballacraine wrote:
Hi Mick,
Does that go for the Legend too?
Nige.
Most definately!
The rear subframe has the latch mount and the priomary airbox has the mount for the lock - in fact the sidcover on that side even has a flat where the lock should be. You need to obtain a key lock and latch (same as most triumphs and kawasakis from that period) a pull cable (the stock TBS one is just about long enough) and the latch pawl for the underside of the seat (again most triumph and kwakwers).
Then all you have to do is:
1. drill the side cover so the lock will poke through (fit the TBS rubber lock gasket to the hole).
2. bolt the latch assembly to the subframe
3. fit the latch pawl to the underside of the seat so it lines up with the latch (you may have to pack out the height a little)
the pic shows a 97 seat that I converted to fit - but its much the same for yours.
and Bob's your uncle! :-D
For a slightly easier conversion, you can do this with the lock:
Tri2fly fitted this to his TBird instead of fitting a lock to the sidecover. You just pull on the ring to release the catch.
P.S. Funninly enough your Legend seat will even have that mounting location for the handbook - though its currently of no use to you.
[ This message was edited by: MickMaguire on 2006-07-19 11:31 ]
