Trident-Exhausts.comAdvanstarMotorcycleShowsMotorcycle.com
BikeBandit
Old 06-30-2006   #1 (permalink)
As I was giving my bike a proper and thorough cleaning I discovered that I could easily change gears at the foot lever without engaging the clutch lever.
This happened as I was cleaning the gear selecting foot lever and it very easily slipped up into 2nd from neutral. Then playing around with it a bit I discovered it pretty easily went through any of the gears. I have not tried this with the engine running, nor do I plan to.
Is this normal or an indicator of some larger issue? I have not noticed anything funny with how the transmission has been acting or anything like that. The oil was recently changed and has less than 1000 miles.
Upon further investigation I did discover that the brake fluid in the hydraulic clutch system is cloudy. I plan on flushing that system out and refilling it today, but I fail to see how this could be linked.
Any thoughts would be appreciated!
magistermatt is offline   Reply With Quote
Old 06-30-2006   #2 (permalink)
jimmyj900's Avatar
YES.
It indicates that your transmission is working normally.
Jim
http://s279.photobucket.com/albums/k...0Head%20Stuff/
Old 06-30-2006   #3 (permalink)
Favorite Bike: 2000 Sprint RS--Beowulf
seumas's Avatar
Other Motorcycle: 1995 Sprint 900--FrankenS
Motorcycle transmissions are designed such that up-shifting without the clutch is relatively easy. I usually use the clutch for starting out and the 1-2 up-shift only. After that I just roll off the throttle and toe the lever up into the next gear. With a little practice the shifts are just as smooth as if you're using the clutch. Down-shifts are a little trickier, but can be done. I prefer to use the clutch for them.
Is fhearr fheuchainn na bhith san duil.
seumas is online now   Reply With Quote
Old 06-30-2006   #4 (permalink)
Favorite Bike: Well, Duh!
MickMaguire's Avatar
Apparently clutchless downshifts are not a good idea - adds excessive wear to the selector forks or so I am told.
Mick...
Old 06-30-2006   #5 (permalink)
I dont think I've ever ridden a bike that couldnt do clutchless shifts. I generally dont use the clutch on upshifts, downshifts I clutch and blip the throttle.
JWoodsie is offline   Reply With Quote
Old 06-30-2006   #6 (permalink)
Well this is good to know. Thanks everyone. I knew that it could be one of those duh! type things I never really understood. But you know what they say, the only stupid question is the one you don't ask.
Gears / Gear Changing? GrahamG Sprint Forum 12 05-01-2007 12:59 PM
Anyone had trouble changing gears (2-3)? Percanto T3 Sport / Touring Forum 6 09-05-2006 02:57 PM
Problems changing gears and getting into nuetral J_J Twins Talk 16 04-23-2006 07:39 PM
Clutch clearing/ gears crunching Hinckley Classic Triples 16 06-06-2005 05:04 AM
Changing gears LRS Tiger Chat 6 06-10-2004 02:54 AM
