Motorcycle.com
Old 06-12-2006   #1 (permalink)
willyjim
Looking at a 1995 t-bird with 10K on the clock. The engine seems a bit noisy at an idol compared to my older twin. I am told the water cooled triples have a bit of upper end noise. Otherwise the bike runs strong. No noise a running speed. Anyone have any thoughts on this?
Jim B.
Old 06-12-2006   #2 (permalink)
Spooner's Avatar
Jim B.
If there's a diesel rattle at idle which lessens when revving the engine a little it's quite likely that one of the impellor bolts has sheared. It's VERY common on the older T-birds. The loose head of the bolt will be what cause the rattle. If the T-bird you're looking at is at a dealer you might want to ask them to take a look at the impellor bolts on both sides of the engine i.e. alternator side and clutch basket side.
I recently fixed mine and now the engine sounds like a dream at idle...no annoying rattle or clonk anymore....my bolt had sheard on the clutch basket side.
EDIT: Mine sheared at around 12,000 miles.
[ This message was edited by: Spooner on 2006-06-12 12:03 ]
S.P.O.O.N.E.R.
Huh?
Speedy MattHilda & Thunderasaki
Spooner is offline   Reply With Quote
Old 06-12-2006   #3 (permalink)
Tre900's Avatar
I remember mine sounding like a loud sewing machine before I gutted my pipes. Although I still hear it, it is slightly covered but a louder exhust note.
If the pipes are stock I would say it *could* be normal. Of course, without hearing it it's hard to say.
Just my $00.02
_
(_)=='(_) "..Get your motor ruuunin'..."
Tre900 is offline   Reply With Quote
Old 06-12-2006   #4 (permalink)
Favorite Bike: 95 TB & 07 Tiger ABS
Jim....
Yes, it's a noisy but very solid engine. Ball bearings in a coffee can, gravel down a chute - take your pick.
Spooner's note about the impellor bolt is a valid one - but tricky for a newbie to identify. If you take a note of the VIN, you can call your local Triumph dealer and see if the service bulletin on the sheared bolt has been done or not.
Chris
"Panniers can never hold everything you want, but they CAN hold everything you need."
parrycm is offline   Reply With Quote
1996 to 1995 885 engine swap Jacksf Modifications & Workshop Talk 1 04-21-2007 08:28 PM
1995 D12 Cam chain noise tritonwow Daytona Deliberations 4 04-14-2007 03:16 AM
Thinking of rebuying my 1995 T-Bird jamboa2003 Hinckley Classic Triples 3 01-06-2007 07:58 PM
98 T-Bird Sport noise in right side of engine du_ratai Hinckley Classic Triples 12 05-01-2006 03:06 PM
Engine noise Triumph SuperSports 2 07-06-2004 10:23 AM
