Motorcycle.com
Old 06-10-2006   #1 (permalink)
Today I decided to remove my fuel tank to remove the loose paint in the neck and figured that while my bike was partially disassembled I would do some additional maintenance.
One item on my list was removing my D&D 3-into-3 exhaust to clean the surface rust developing between the pipes. When I began to remove the last downpipe I noticed the one of the cylinder head bolts was sheared off. (See Image). I do not know when this happened. I've had the bike for two years and this is the first time I've taken off the pipes. Though it could have happened the last time I adjusted my chain and loosened the rear support bracket for the exhaust assembly. In any case, the bike has been running fine. But what do I do now?
I thought about J-B Weld, but it is not recommended for temperatures above 500 F. I imagine the cyclinder head ports and that bolt are about as hot as anything on the engine. Is it hotter than 500F?
Can that part be welded back on?
Also, contrary to the Haynes manual there were no gaskets in the cylinder ports. Should there be?
Thanks for your help.
Rob
Photo Album
Otrorob is offline   Reply With Quote
Old 06-10-2006   #2 (permalink)
I would recomment trying to extract it before welding it. You migth be able to JB Weld it together and then remove the stud from the head.
[ This message was edited by: TBSstunta on 2006-06-10 12:22 ]
2000 TBS Cafe Racer :: 2000 Frankenmille
TBSstunta is offline   Reply With Quote
Rear master cylinder bolt goes airborne Lanont Twins Technical Talk 3 05-20-2007 05:56 PM
Cylinder head interchange GrandPoohBah Classic, Vintage & Veteran 24 06-13-2006 12:31 PM
Cylinder Head clive955 Tiger Chat 0 03-15-2006 02:54 PM
Pre unit head gaskets nortonmercury Classic, Vintage & Veteran 0 05-29-2005 01:53 AM
Cylinder Head Saga Tiger Chat 14 04-17-2005 02:30 PM
