JBWeld is a great product, but the tensile strenght is not enough to last forever. You can probably take that to a metal fabrication shop that welds aluminum and they can fix you right up, a little black paint and you'll be good as new.
On second thought I doubt that is aluminum, probably cast steel, you can check with a magnet. That would make it even easier to find someone to weld it back together and it would probably be stronger than it was when new.
Russ,
