Took me a while to decide myself but finally opted for the Technoflex shock. One factor is that they have no distributor in Canada and the price quoted by technoflex was quite good. The other reason is that the shock has low speed and high speed adjustment.
quality of construction is in the range of Ohlins, on the service side, I would say better. They did ask me my weight, type of riding and send me a sheet explaining how the shock was adjusted to start.
It was fairly easy to put in, only needed a small change in the battery holder. I guess they did good calculation, the spring preload is properly adjusted, bouncing the back of the bike is now a very different feeling than the stock shock. I want to go and try it.
Now, the biggest problem, I can not try the bike, it is minus 15, full of snow, what a pity.
In doubt, crank the throttle.
