Old 05-25-2006   #1 (permalink)
kurtrude
okay..i'm stupid, how to i pop this off so i can get to my battery? i can unlock the back but it only pops up an inch!
any help would be appreciated.
d
Old 05-26-2006   #2 (permalink)
Favorite Bike: 98 Thunderbird
Once you have turned the lock you should be able to lift the seat off. You have to ease it back at the same time because the front locates under the tank.
Old 05-26-2006   #3 (permalink)
Tre900's Avatar
I have fount sometimes that my seat lock requires me to put my key in a spicific way so if it doesn't come off try flipping your key over.
Just food for thought.
_
(_)=='(_) "..Get your motor ruuunin'..."
Tre900 is offline   Reply With Quote
Old 05-26-2006   #4 (permalink)
Favorite Bike: Well, Duh!
MickMaguire's Avatar
grasp the rear of the seat, push down on the back as you turn the key then holding the key in the turned position lift up the rear of the seat (it may need a wiggle). then as slinky says pull it back a little as you lift the seat right off.
Mick...
Old 05-26-2006   #5 (permalink)
When you get the seat off, I recommend removing those little hooks on the bottom of the seat. I find its much easier to pull it off and reinstall the seat.
99TBS and 2000 Sprint ST
fbird is offline   Reply With Quote
Old 05-26-2006   #6 (permalink)
Not recommended if you ever take passengers.
It seems that they are there to stop the seat coming off while riding if a passenger should pull up on the grab strap or sides of the seat.
Mick...
Old 05-26-2006   #7 (permalink)
Interesting, didn't think about that. Never had a problem riding with a passenger. That explains why they are not on my solo seat. Thanks for the info.
Old 05-26-2006   #8 (permalink)
If its really snug just take a file to those hooks and remove a little.
[ This message was edited by: TBSstunta on 2006-05-26 09:32 ]
2000 TBS Cafe Racer :: 2000 Frankenmille
TBSstunta is offline   Reply With Quote
Old 05-26-2006   #9 (permalink)
I think its just to keep the seat from flexing its way out of the latch, this may or may not be possible depending on many things like how much wear is in the latch
Mick...
1998 Thunderbird Sport seat cully Hinckley Classic Triples 13 06-15-2006 06:32 PM
1998 Thunderbird Sport Seat cully RAT - United Kingdom 1 06-07-2006 01:40 PM
Thunderbird Sport seat Kem770 Hinckley Classic Triples 3 03-29-2006 09:20 PM
will a thunderbird tank fit a thunderbird sport? aeycue Hinckley Classic Triples 1 06-24-2005 03:54 PM
