Old 05-23-2006   #1 (permalink)
The bike has a noticeable notch when I turn the forks with the front wheel off the ground. There isn't any freeplay so its not a case of them being loose. The notch happens when the the frost are straightened out, like I'm going straight down the road. So has anyone done this fix?
[ This message was edited by: TBSstunta on 2006-05-23 06:56 ]
2000 TBS Cafe Racer :: 2000 Frankenmille
TBSstunta is offline   Reply With Quote
Old 05-23-2006   #2 (permalink)
jimmyj900's Avatar
The bike has a noticeable notch when I turn the forks with the front wheel off the ground. ... The notch happens when the the frost are straightened out, like I'm going straight down the road.
All it takes is a few potholes.... :wink:
I just replaced my front bearings and it's not a difficult job if you spend the money on the correct Triumph tools.
You'll also need a 300mm piece of 10mm threaded rod and a couple of heavy nuts to pull the bearings in. McMaster carries the rod and ships same day. (www.mcmaster.com)
Jim
http://s279.photobucket.com/albums/k...0Head%20Stuff/
Steering Head Bearings andyc740 Trophy 1 02-14-2008 10:06 PM
STEERING HEAD BEARINGS blacktiger Tiger Workshop 8 06-13-2007 09:30 AM
steering head bearings spazz T3 Sport / Touring Forum 1 06-07-2007 10:51 AM
steering head bearings firsttriumph Sprint Forum 3 07-15-2006 07:29 PM
STEERING HEAD BEARINGS blacktiger Tiger Chat 2 10-03-2005 04:20 AM
