Motorcycle.com
Old 05-12-2006   #1 (permalink)
Spooner's Avatar
Passed my inspection today with flying colors! Quite a relief considering the modifications I've done!! I really must find another slipon....the one I got on passes MOT!! Totally unacceptable ofcourse! :hihi:
Any ideas for a slipon?? Inlet diameter of inlet pipe must be 2".
I changed my carbs from Mikuni to Keihin last week. I'm very happy so far! My mpg's are up from 40mpg to 47mpg. The Keihins seem much smoother!
My current setup is:
One extra hole in airbox on opposite side, 40 pilots, 2 shims on each needle, 115 mains.
I've got a feeling I'm running a bit lean...I'm popping quite a bit on decel especially when the temp falls....hmm, maybe that's why my mpg's are better :-D
Anyhooo...no more shooting in the dark so I'm getting a dyno run next week!
Edit: F in spelling
[ This message was edited by: Spooner on 2006-05-12 09:17 ]
S.P.O.O.N.E.R.
Huh?
Speedy MattHilda & Thunderasaki
Spooner is offline   Reply With Quote
Old 05-14-2006   #2 (permalink)
Spooner Dude,
Ive done this mod on the same year model. Dont forget you also need to:
Turn all 3 mixture screws another ONE complete turn OUT to enrichen the mixture or it runs lean and the idle wont settle !
Replace the restricted Mikuni carb rubbers (with id dimple) for smooth unrestricted Keihin (CVK) ones !
I would have thought that 115# mains were slightly on the small side ive got #120 mains and only one copper washer under each needle.
Some folk who presumably live at altitude go to #125 or#130 but I would have thought they were on the big side.
Ive also changed the plugs for NGK Iridium ones and am happy ive got mine just right - smooth power delivery no flat spots and no popping !
By the way what is your VIN number and mileage (kmage) just so that I can plan my alternator bolt crisis later on !
BigVinny is offline   Reply With Quote
Old 05-14-2006   #3 (permalink)
Spooner's Avatar
On 2006-05-14 02:19, BigVinny wrote:
Spooner Dude,
That's right! I forgot about you and switching to Keihins!
I've done everything...my mixture is 2.5 turns out, the carb rubberettos are unrestricted (never had the restricted ones)..needed to get new ones for the Keihins though...different fitting.
It could be the jetting...it could be the exhaust pipe....or it could be the weather :hihi:
I'm thinking of getting a supertrapp muffler on her...and then head off for a dyno run.
I'm done shooting in the dark....turns out my butt-dyno wasn't very accurate :moon:
My VIN is 45970 (last five digits). My bolt must have broken off sometime last summer...I'd say I had about 16,000 miles on the speedo at the time.
The good news is it seems like an easy fix....I'd say 2 hours with someone assisting.
Let's rock!!
S.P.O.O.N.E.R.
Huh?
Old 05-14-2006   #4 (permalink)
My VIN is 44562 so I guess it is just a matter of time !
One other way to experience popping occurs when the clamps around the carb rubbers arnt tight and the rubber/metal seal is not good.
Keihin VS Mikuni Carbs jlbonnie2000 T3 Sport / Touring Forum 3 06-15-2007 11:03 AM
Mikuni to Keihin swap - rubbers and cables carpelux Hinckley Classic Triples 10 03-23-2007 12:28 PM
Mikuni to Keihin swap EdC Hinckley Classic Triples 2 09-20-2006 12:00 PM
keihin vs. mikuni fuel economy? bassspeed Trophy 1 10-09-2005 09:50 AM
Mikuni or Keihin Spooner Hinckley Classic Triples 4 08-15-2005 09:49 PM
