Hi
The long strap is just for adjustment. Put the panniers over the frame with the seat off, fasten the poppers around the frames and then adjust the long strap to take the weight of the bags. Shouldn't be a problem, although getting the poppers fastened can be fiddly.
Do you have the key lock or bolt on seat? I think the panniers are for the bolt on seat - is that the problem?
Cheers
nil illegitimo carborundum
