Sorry for being too vague in my initial inquiry.
When the ignition key is turned on before starting, the high beams, neutral, and oil warning lights turn on. I figure that one of the next two above these three, is "coolant temperature - too high".
I don't know what the other one is (not even shown in the wiring diagram in Haynes "Triples and Fours 91 to 99").
So two questions:
1. Should the two upper warning lights turn on to signify they are operational when you turn on the ignition?
2. What do these two lights signify?
Thanks,
Rick
