Old 05-05-2006   #1 (permalink)
ToddZimardo
I need to replace the rubber gaskets or bushings on the upper part of the fork on my 96 T-Bird.
Does anyone know the name for these parts, I need to help the local shop as I have had a less than normal experience in the past.
Thanks!
Old 05-05-2006   #2 (permalink)
Your local shop should do everything based off parts diagrams. So they will be able to visually see what part you are looking for. Look over their shoulder and point out what it is.
2000 TBS Cafe Racer :: 2000 Frankenmille
TBSstunta is offline   Reply With Quote
Old 05-05-2006   #3 (permalink)
Favorite Bike: 98 Thunderbird
Do you mean the rubbers at top and bottom of the headlamp brackets?
If so the part is T2700340 and they call it a Grommet, mounting tube (snappy name huh?)
Old 05-07-2006   #4 (permalink)
NCB
I had the same problem, disintegrated headlight mounting tube grommets, and what I got was these little rubber dealies that I still don't know what they're for. Something around the headlight, I guess. I had a heck of a time installing the actual parts when I got them finally. Does anyone know an easy way to install them I can use next time I want to change my fork oil?
NutCaseBob
[ This message was edited by: NCB on 2006-05-07 02:19 ]
NCB is offline   Reply With Quote
Old 05-07-2006   #5 (permalink)
not sure why it was hard for you. all you have to do is slide the bottom one over the fork, seat the shroud over it and then put the top one one. maybe it would be easier if you unbolted the headlight so you can do them separately.
Old 05-07-2006   #6 (permalink)
NCB
My problem stemmed from the fact that there wasn't enough space to assemble the thing between the upper and lower triple clamps. I had to use grease on them to allow them to slide into place.
Gaskets! KitNYC T3 Sport / Touring Forum 9 02-07-2008 02:16 PM
Fork Gaiter Part # | Thruxton | Australia Chalawah Club Cafe 2 06-11-2007 11:31 PM
What are the part #'s for Fork seals what Suzuki parts? trypcil T3 Sport / Touring Forum 0 01-10-2007 08:08 PM
350$ to replace fork rod assembly!! roadkill Speed Triple Forum 3 08-13-2006 12:41 AM
How To Remove Upper Fork Clamp? Brooksie Daytona Deliberations 10 06-18-2006 12:29 PM
