AdvanstarMotorcycleShowsBikeBanditTrident-Exhausts.comMotorcycle.com
Old 05-23-2004   #1 (permalink)
hi guys,
Put the slash cut "off road" pipes on and the single side (#1) had a honeycomb insert about 3.5" long in the inlet of the stock megaphone silencer. I left it out when I put the slash cuts on and it sounds like the left side exhaust has a brassy sound (too much treble) kinda like open Harley pipes. I have two questions:
1. Was I supposed to put this in the left side? (right 2 into 1 pipe did not have it)
2. Is it OK to leave it out if I like the sound the way it is?
Oh yeah #3 Will the new slash cuts be less prone to blue up on the 2 into 1 side since they are open and might not retain heat as bad as the megaphone style?
Please advise on all three questions if you can, and thank you,
Old 05-23-2004   #2 (permalink)
jimmyj900's Avatar
I thought it sounded like I was being followed by a Harley on the right and a lawnmower on the left when I put the slashcuts on my Adventurer.
1 & 2) I don't have anything like your honeycomb thingie in my exhaust, so I guess it's not a problem.
3) Your pipes will blue faster/farther since the open exhausts will tend to lean the mixture a bit above an idle.
The consolation here is that folks will know you actually ride the bike rather than just sit around and admire it. :-D
Jim
http://s279.photobucket.com/albums/k...0Head%20Stuff/
Insert Image Hedge Twins Technical Talk 26 07-21-2007 08:55 PM
How to insert an IMAGE... ggRAT Twins Talk 3 09-30-2006 08:09 AM
05-06 right hand mirror insert wanted DrTriumph Sprint Forum 5 08-31-2006 08:36 AM
Muffler/Silencer Insert Fix FALSTEN Modifications & Workshop Talk 8 12-01-2003 10:00 PM
