AdvanstarMotorcycleShowsTrident-Exhausts.comBikeBandit
Old 04-28-2006   #1 (permalink)
I just installed my race tech springs in the legend. While disassembling the forks I found progressively wound springs in each leg! I thought that only the old T-Birds ( 95-98ish? ) had progressive springs in them. Interesting, no? Did the 01 Legends come with progressive springs?
By the way, the old fork oil was purple! Weird, indeed.
Avatar is offline   Reply With Quote
Old 04-29-2006   #2 (permalink)
I recently replaced the fork oil in my 97TB for the fist time, the original oil was red.
The standard springs that I took out were non progressive that is the coils have the same spacing pitch all the way down.
In one of the legs the washer that sits between the spring and the top spacer tube was missing. Since the forks had not been opened up from new someone in the factory (in Japan) must have forgot to put it in.
Got a new washer by post from Jack Lilley in under 3 days - very good service !
BigVinny is offline   Reply With Quote
Old 04-29-2006   #3 (permalink)
Favorite Bike: 98 Thunderbird
When I changed the fork oil for the first time, I found completely different oil levels in each leg.
Maybe they assemble forks on Friday afternoons ( after a lunchtime session down the pub). :???:
Old 05-01-2006   #4 (permalink)
Favorite Bike: Well, Duh!
MickMaguire's Avatar
My 2k TBird legs had progressive springs from new. there was at least 1 change point in the design of the front forks and 1 change of manufacturer so differences between the years is to be expected even if they all look the sameon the outside. Color of the fork oil means very little.
Mick...
2001 Triumph Legend TT capt_solo4 Speed Triple Forum 4 04-11-2008 12:38 AM
TBS and Legend 2001 Gone Cat Hinckley Classic Triples 2 01-01-2008 05:06 AM
2001 Girlie Fork Spring Upgrade Suggestions bluzdoctor Tiger Mods & Bolt-Ons 2 07-11-2007 09:38 PM
2001 Triumph Legend TT capt_solo4 Modifications & Workshop Talk 1 05-24-2007 03:52 PM
Found a 2001 Bonnie Kem770 Twins Technical Talk 17 11-28-2006 08:17 PM
