All good in the headlight assembly, but problem persists. I think that I have found the problem, but would be interested in what you all think:
I've been having some electrical problems and have been tracing wires, etc.
Problem has been when putting in the key, sometimes there are no speedo or tach lights or any lights. Absolutely no power to anything, including starter button.
When the lights do come on, the bike starts right up.
Seemed to correct itself when cooled, but also when I'd "jiggle" wires in and around the battery/fusebox area.
Anyway, it was acting up again, so I started getting specific with my jiggling around the battery/fusebox area and "jiggled" what appears to be called the "indicator relay" at least judging by the colored wires attached and the wiring diagram in the manual.
It is a box with three leads and is mounted to the outside of the fusebox. One of the leads from this box has some "bluing".
Could the indicator relay cause the problem that I've been having? Does it sound like just a bad/loose connection or could the relay be fried?
Any input is much appreciated.
Give me 900 cc's of power....STAT
