Hi,
I will start with my question:
Can I still ride this bike untill I get the carbs set up for my modifications, or is it a bad idea?
The Legend I bought last year came with a K&N air filter installed. I also got a pair of
Raask Minizoom mufflers with the bike, which were not mounted at the time when I bought it. I have now put the Raask mufflers on but haven't done anything at all with the carbs. Unfortunately I don't know if the previous owner did anything either, so I have no idea if the carbs are set up as they came from the factory.
The bike still runs pretty ok after I put the Raasks on, but I guess it is a bit lean after the mods? It also goes up to 1500-2000 RPM on idle. I have booked a time in the workshop in three weeks from now, hoping to get the carbs set up to better suit the K&N and Raasks.
But again, can I still ride this bike untill then without any adjustments to the carbs, or will something get damaged? I don't want to put the bike in the garage for three weeks, but I don't want to destroy it either
Thank You very much!
Daniel
