TBS air filter box idea - Triumph Forum: Triumph Rat Motorcycle Forums
Old 05-08-2004, 11:57 PM   #1 (permalink)
Thunderbird Sport Air Filter Change Modification.
I followed the article on how to replace the air filter and decided to make a modification. Before I replaced the air-box I cut the U-shaped air box (rear section) in half. I reasoned that if you could remove the air box in two parts you would not have to remove the carbs and the front section of the air-box. The U-shaped air-box has a mold release line down the center that I used as a guide to cut the box in half, this also cuts the bottom bolt hole in half. Clean up the cut marks with a file or sand paper than cover one side of the cut with silicon seal so that the gap will be-closed when the air-box is bolted up. The bolthole, which was cut in, half will need some help. I used a piece of metal 1 inch long and bent up both ends leaving about a ½ inch center section. Drill a hole in the center of the metal for the torx bolt, use some lock tight and set this bolt in the bottom of the air-box. Then tighten this bolt just enough so when you install the air-box half’s the bolthole will slide behind the metal bracket. Install the rest of the torx bolts and finish up with what’s left. Next time you change the air filter remove 9 torx bolts and pull the U-shaped air-box in half.
Old 05-10-2004, 11:19 AM   #2 (permalink)
Neat idea! I did something similar when I replaced the condensor on for an A/C on a 90's Mustang. All I had to do was remove the glove box and could get to it from there..
Dave Arnold
'04 Rocket III
'00 Trophy 1200
La Vernia, TX
tbsrider2000 is offline   Reply With Quote
Old 05-10-2004, 03:34 PM   #3 (permalink)
Favourite Bike: Depends on mood
Ballacraine's Avatar
Other Motorcycle: Brit, Italian & American
Yes, that sounds a decent idea.
I don't suppose you took any pics?
Nige.
In faecorum semper solum profundum variat.
(Always in the s**t it is only the depth that varies)
Nige's Gallery
Ballacraine is offline   Reply With Quote
Old 05-11-2004, 09:38 PM   #4 (permalink)
No I did not take pictures, I will the fix that and get some pics of the bike and air filter box. :whoops:
Old 05-12-2004, 04:16 PM   #5 (permalink)
Thanks a lot.
This modification sounds quite promising.
( Now if we can find some way around that bisected hole issue! )
Nige.
Nige's Gallery
Old 05-28-2004, 10:45 PM   #6 (permalink)
Pic's of the air filter can now be found at the Photo Album Shop Scrapbook menu (2nd page).
Old 05-29-2004, 12:24 PM   #7 (permalink)
Favourite Bike: '98 Triumph Sprint Ex.
Extra Motorcycle: '02 Kaw Ninja 250
That's a great idea! It should work on T-birds, Legends, Adventurers, Sprint 900's, Tridents, Trophys and all the other older T-3's. I'm going to do it the next time I'm in there.
j98
j98sprint is offline   Reply With Quote
air box/filter options CCR Hinckley Classic Triples 5 07-12-2007 06:04 AM
TBS air box sean_x Hinckley Classic Triples 6 05-28-2007 09:29 PM
Air Filter Box roadrunsl T3 Sport / Touring Forum 3 08-13-2006 06:16 AM
TBS / t'bird / Adventurer air box. johnyC Hinckley Classic Triples 3 12-02-2005 10:25 PM
Replace air box/filter with K&N ? KenT140D Hinckley Classic Triples 7 06-11-2004 12:21 PM
