Old 05-06-2004   #1 (permalink)
Just bought a 98 t-bird with 24,000 on it looks like new, runs good but having trouble getting idle to stay put and I hear some popping maybe from #3 but not sure, also it has a lot of to[p end noise. I don't have much history on it but from looks and accesories I would guess it was very well maintained.
Chris :???:
Old 05-06-2004   #2 (permalink)
hi there,
My adventurer does the same thing. #3 pops at cold start quite intermittently for about 1 minute. I checked vacuum when hot at 3,000 rpm on all three carbs and get a balanced 10lbs. plugs foul evenly too so i have come to accept it as no big deal. My top end is loaud too! 10k miles. the service manual recommends a valve lash check at 12k so I guess i'll worry about it then. Without triumph 885's at every red light, it's hard too tell if this is all normal stuff! I feel your pain brother!
I'll let you know if the damn thing blows up.
Old 05-07-2004   #3 (permalink)
mecscc's Avatar
Chris: if it pops on deceleration, that is pretty common; also during warm-up; if it pops all the time it is likely the carbs are out of sync or that you are running a bit rich. You can pull the plugs and see if they are black or oily etc. to tell that. If aftermarket pipes or modified airbox is on your bike that can cause the popping, as can timing being slightly off, or an air leak in one of the carb boots, etc.
Top end noise is fairly common, but may indicate that your some of your valve clearances are too loose and need adjustment - a frustrating task because of the use of shims. Good news is that loose, which causes most of that noise, is much better than too tight, which can burn up valves. Also, the cam chain adjuster can be hanging up, not as likely on the new bikes as on my old ones. If the top end noise is bad at idle and goes away above 3K rpm it is likely that is the problem; if it is constant, then it is something else, likely valve clearances, which I would not worry about. But at 24,000 you are scheduled for a valve clearance check anyway.
If you don't have a shop manual, at least a Haynes, I'd suggest getting one if you are going to work on it yourself, of at least so you can know what you are going to try to tackle yourself and what you are going to pay the dealer some of your blood to do - and so the dealer won't be able to blow smoke at you telling you the problem is worse than it is.
Perhaps some of the guys who do all their own work, I don't anymore, will chime in here with some thoughts.
My last thought on the question might sound a bit strange, but you can't go by the appearance of the bike to tell hardly anything about mechanical maintenance. Some guys simply want their bikes to look like jewels and ignore the mechanical aspects until the bike blows up. Other bikes look like they have been "well ridden" but have been maintained mechanically very well. Often times if you don't know anything about how to maintain a bike, well, at least you know how to keep it looking nice, if you know what I mean.
Have someone who knows something about Triumph triples (preferably another owner who does some of his own wrenching) take a good look at it. I would if it were mine. 24K miles is THE major maintanence interval on these bikes, covering a lot more things than we are discussing here.
Good luck,
Monte
Monte
"The Old Ohio Preacher Man"
Old 05-08-2004   #4 (permalink)
Monte
Thanks for the input, one of the things that makes me think it was maintained well is the addition af an ohlan shock which I understand are big bucks, I realize that 24K is a major service point and am debating on bringing it in or just biting the bullet and doing it myself, I did order a aftermarket service manual (haynes), I am nervous about messing with the carbs and getting them out of sink, I am an OK car and boat mechanic, old school, but real unfamiliar with bikes, Haven't owned one for 20 years and the last one was a 70 bonneville, but I will pursue your sugestions once I get some reading under my belt, and glad you told me about the valves cause I was really worried I would damage something by riding it.
Chris
Speed & Street back to back ride. Reppyboyo Street Triple Forum 11 02-07-2008 06:08 AM
popping kc dave Trophy 23 01-30-2008 10:51 PM
TOR's back firing/popping peppington Club Cafe 16 07-05-2007 11:04 PM
MCN rides 675 back to back with R6 et al Wildpig Daytona675 Forum 12 02-10-2006 11:22 AM
'00 Legend off road pipes popping back too much Hinckley Classic Triples 14 07-29-2004 12:01 PM
