Motorcycle.com
Old 02-08-2004   #1 (permalink)
I had vibration on my 1997 Sprint Sport. It came through the right hand grip & became intensely painful on runs.
It was moderately high frequency (felt slower than engine revs & faster than wheel revs - see posting from Metro DC above). It was of small but noticeable amplitude, got bad by 70mph & never went away. If I was "trying hard" I forgot to notice it but as soon as I had miles to cover & held a steady speed I noticed it alrught.
I put it down to bad handlebar angles & old bones (me).
The a mechanic suggested I had a loose bolt on the sprag clutch & alternator drive shaft.
He was right. The shaft is splined along it's length with no step, so a loose bolt on one end makes the other loose as well. The bolt was actually sheared off and both drive gear & alternator drive cup were happily rattling around on the shaft.
Curing this sorted the vibration and made the engine much much smoother. It made it so much better I almost kept it, but then I test rode a Speed Four. So it had to go.
Incidentally this is not an easy job. Stripping fairing, coils & carbs is routine for almost every job on the Sprint. Taking the clutch off is not hard if you use the rear brake & a friend. Forcing the new drive shaft through held tight up-against the old one (to avoid washers & spacers falling into the sump) is nerve-racking but okay. BUT Putting the clutch centre back through the clutch & oil-pump/alternator drive gear woudl try the patience of a saint. If I ever have to do that again I will drain the oil & lie the bike on it's Left side so that the gear stays in one place & in mesh as you thread the clutch centre through.
Hope no one else has this problem & if you do I hope this helps
Old 02-10-2004   #2 (permalink)
Favorite Bike: Tiger 1050
Other Motorcycle: Honda Transalp
I think the alternator bolt problem was solved in later models, but not sure when. Ask a reputable dealer! Anyway - my TBS (an '03 model) had a vibe at around 3500 rpm when it was new, but it seems tro have disappeared at around 1000 miles - or maybe I rev it higher now - whichever it doesn;t seem to be nioticable any more! Stick with it!
Eagle
Time flies like an arrow...
Fruit flies like bananas
eagle is offline   Reply With Quote
Vibration, Etc. rickster Daytona Deliberations 0 08-15-2007 01:52 AM
Vibration 4_Philthy Sprint Forum 4 02-15-2007 04:36 PM
Vibration STRider Speed Triple Forum 3 06-14-2006 05:18 AM
HELP - Vibration LaughingDog T3 Sport / Touring Forum 9 11-29-2005 03:23 PM
vibration dougl The Rocket Science Forum 2 07-01-2005 05:24 PM
