Motorcycle.com
Old 03-02-2006   #1 (permalink)
Favorite Bike: 95 TB & 07 Tiger ABS
Recently, my TB started spitting fuel into the airbox. Only noticed it when I found a slow drip of fuel from the corner of the airbox when the bike was leaned over on the sidestand.
I checked it out with RPM here in Dallas and they diagnosed worn o-rings in the float chambers allowing fuel to leak past. They sold me some suitable o-rings and ordered the float bowl gaskets.
I started the bike with the petcock closed and used up the fuel in the line and the carbs. Then pulled the tank, horn, side covers and carbs (see tip at bottom). Inverted the carbs, undid the two allen bolts holding each float bowl, pulled out each float assembly, replaced the two o-rings, cleaned out the float bowls, replaced the gaskets and re-assembled. Not too difficult - less than one hours work.
Remounted everything and went for a ride. Bike was running well for about 60/70 miles with a couple of stops and then, as I headed for home, she gave a bit of a splutter. Checked the trip and yes, she needed to switch to reserve. She went onto two cylinders and stayed like that to the gas station. She did this once before and I figured it was just the carb furthest from the fuel line not getting enough becuase I was slow switching over. But even when I filled up, she stayed on two cylinders. OK at idle but above 2000 revs, nbr one would just cut out.
Because she'd run so well, I figured I had a new, separate problem to the job I'd done. I was thinking fuel starvation due to sucking up some gunge as the tank got low, so I checked and cleaned the inline fuel filter between carb two and three. No go. Then drained the tank, removed the petcock, found loads of cr*p, disassembled it, cleaned it and even got a tube into the tank and sucked up any loose bits. Still no go. Sh*t - pull the carbs again!
Since nbr one was the bad 'un, I opened the float chamber on that first and checked my work. Everything looked kosher and was a good fit. So, baffled, I was about to reassemble when something caught my eye. Something in the needle jet? Unscrewed it and held up to the light and yes - definitely something. I winkled it out using a pin (VERY GENTLY) and it was the tiniest, tiniest piece of blue roll. In other words, my EFFING fault for using a linty cloth to clean the float bowls in the first place. B*llocks!
It must have lying in the bottom, and got sucked up when the fuel got low, and was just big enough to jam but not big enough to block completely. Anyhow, just to be sure, I checked the other two chambers for lintiness and put it all back together again.
Bike is running well now, haven't seen any fuel from the airbox, but I'll keep an eye on that one.
USEFUL TIP. Screw one side cover mounting bolt into each side of the airbox - only part way though. Now use those screws as mounting points for a long bungee cord. Loop the bungee over something at the back, like the seat mount or the tail light, so that the airbox is pulled to it's rearmost position and stays there. Now you can use both hands to manhandle the carbs in or out.
Cheers
Chris
"Panniers can never hold everything you want, but they CAN hold everything you need."
parrycm is offline   Reply With Quote
Old 03-02-2006   #2 (permalink)
Favorite Bike: 2003 Trophy 1200
Other Motorcycle: 2001 Legend TT
You must be a lot smarter than me, doesn't take much. I have struggled with remounting the carbs on two occasions and haven't dismounted them again due to the difficulty in remounting them. This is an excellent tip and I am grateful for the advice. Next time I may not have to lose my religion just to fiddle with the carbs.
Flybiker
flybiker251 is offline   Reply With Quote
Old 03-02-2006   #3 (permalink)
Something else I found out: the intake rubbers between the engine and the carbs are NOT straight - they are slightly angled. If someone has removed them and not put them back correctly, this will slightly reduce the clearance between them and the airbox, and make it harder for the carbs to fit. Even that slight amount makes a lot of difference.
The rubbers should be angled to account for the cylinder bock and head being tilted forward. So, from the side the angle should be an arch and not a "U" - if that makes sense. In fact you can see a moulded ridge running lengthways along the top of the rubber. Just make sure this goes at 12 o'clock.
Chris
some lessons get learned the hard way (saddle bags) kurt_3_0_1 Twins Technical Talk 3 09-26-2007 11:40 AM
Rapp lessons AMA DirectLink News Room 0 08-06-2007 10:00 PM
Redhead Down and lessons learned R100Pilot Speed Triple Forum 16 10-02-2006 11:48 PM
Whata day, and lessons learned...... FattRat Twins Talk 30 01-18-2006 06:36 PM
Trophy CV carbs at varying altitudes.... EFI vs CV Carbs TiggerTwo Trophy 9 01-17-2006 01:07 AM
