AdvanstarMotorcycleShowsMotorcycle.comTrident-Exhausts.com
Old 05-02-2004   #1 (permalink)
Im guessing around 1000 rpm just want to make sure.
Mike
Msullivan is offline   Reply With Quote
Old 05-02-2004   #2 (permalink)
Favorite Bike: 98 Thunderbird
I think you are right, going from memory the specs say 1000 +/- 100 rpm. They will idle quite happily down to about 600 rpm (just lake a Hawg) but lack of oil pressure could a problem at such low revs.
Old 05-02-2004   #3 (permalink)
Favorite Bike: 95 Thunderbird; 96 Sprint
Other Motorcycle: 82 Jota; 79 XS850
Extra Motorcycle: 72 BSA Rocket Three
Hi,
1000rpm is right.
If you wish to be pedantic, it is 1000rpm +/- 50rpm (Triumph Service Manual).
Ciao, Geoff
GeoffE is offline   Reply With Quote
Old 05-03-2004   #4 (permalink)
Favorite Bike: Well, Duh!
MickMaguire's Avatar
I find mine idles best around the 1050 mark rather than the 950.
Mick...
Old 05-06-2004   #5 (permalink)
Favorite Bike: Adventurer
Other Motorcycle: Moto Guzzi 350
having just fitted the desrestricted carb rubbers , I found that idling was lumpy - fixed it by spending some time balancing the carbs. The Triumph "within tolerance range" is quite large 25mmHg - I got mine to within 4-6 mm Hg and checked it under load . Not only smoothed out the idle big time but take off from standing was better and the whole engine just felt smoother . Amazed at the difference - I would recommend it.
frubpato is offline   Reply With Quote
Old 05-10-2004   #6 (permalink)
Yep, same here. Seems to like it about a needle's width past 1000 rpm
'99 Adventurer mikemtree Modifications & Workshop Talk 1 06-07-2007 01:59 PM
Adventurer hillbillydan Hinckley Classic Triples 1 03-19-2006 01:48 PM
Adventurer hillbillydan Hinckley Classic Triples 0 03-17-2006 09:37 PM
01 Adventurer TJL Hinckley Classic Triples 10 12-08-2005 02:16 PM
Adventurer SS? Hinckley Classic Triples 3 06-21-2004 11:56 AM
