number three cylinder quits randomly. The cylinder will refuse to ignite for several minutes and then randomly it will start running again. It does not matter what type of throttle input
I hesitate to say this. I've said it before when everyone else was saying 'coils' & in that instance it *was* coils.....but humour me.
Next time this happens get to a compressed air supply. Turn off fuel tap, & open up & gently blow air up each carb drain plug. (You need a long allen key, 3mm I think, & a bit of plastic tubing helps) This won't fix the problem but it may well get you home. I would suggest that if you try this & find that the 'interval' between misfing episodes is increased, it is indicative of a partial fuel blockage.
This occurred on my T'bird. Randomly misfiring/dying on one cylinder (Left -hand one IIRC). Leave it a minute or two & it started right up again, . Next 'episode' could be in 1km or 40km.
Blowing with the airline just 'mixed up' settled sediment, temporarily restoring flow.
When I stripped the carbs there was a *little* sediment in each bowl, but the real culprit was the hidden in-line fuel filter *inside* the fuel line behind the carbs. It takes *very little* sediment to lodge here to cause the problem you describe. And yes I did/do also have an aftermarket inline fuel filter fitted. The sediment that got through was extremely fine.
I was suprised that when fuel flow was 'centrally restricted' that each carb/cylinder wasn't 'equally affected', but that's what happened. I also *know* it was the inline fuel filter. First time I cleaned out the carbs/fuel tap/aftermarket inline filter, I didn't know about the 'hidden' one. Put it all back together & problem remained. Cleaned the 'hidden' filter. Problem solved. No misfires for past several thousand kms.
regards
Cuppa
