04-23-2004, 09:53 PM
Powerbike Favourite Bike: Favourite Bike
My 2001 Legend emits a "ticking" sound. As I am new to Triumph, I need to ask if this is something to fret over. Is it normal?
The "tick" is most noticeable at idle.
--Avatar
04-24-2004, 01:40 AM
Formula Extreme Favourite Bike: Roadking
well look at this way mine ticks too, i was told if it doesnot tick then start worrying because it,s not running just a normal character in this older style motor very loose tolerances than jap engines which are more refined
04-24-2004, 06:43 PM
The dealer told me this was because of "straight cut" primary gears. I dunno if he was spinning me a yarn or not. It's done 20,000 hard kilometres, the noise is still the same as when new. It seems a little quieter when cold with new oil in it, after a couple hundred ks it goes back to its standard noise.
04-24-2004, 07:34 PM
Do not get confused with a rattle from the alternator area, cause if it rattles at low revs but disappears as the revs rise then it could be the dreaded alternator bolt sheared off.
04-24-2004, 08:51 PM
Just broke 17,000 miles today It "ticked " when I first bought it it still ticks today. Not to worry it's normal.
04-25-2004, 12:55 AM
Site Supporter Pole Position Favourite Bike: 1996 Thunderbird "Nessie"
Posts: 3,563 Other Motorcycle: 1973 Trump TR7RV "Loosie" Extra Motorcycle: 1968 BS 350 GTR "Smokie"
bollocks, shedds - nothing to do with tolerances! Simply the type of design.
The Triumph factory has state of the art equipment, and has had from the beginning. No Jap bike can hold a candle to it in that department...
Scot
04-25-2004, 10:16 PM
Its good to know that the ticking may be considered normal.
Can someone provide a method to check for this alternator bolt problem?
04-26-2004, 11:35 AM
Site Supporter Pole Position Favourite Bike: Well, Duh!
Posts: 3,650 Other Motorcycle: Can't afford two! Extra Motorcycle: Three would be insane
Straight cut gears make a whining sound (like a car in reverse) not a ticking sound. Stright cut primary gears would defiantely be adding to the overall noise you get from a T3, but would most likely be that whistly/whine noise you get as you rev it.
Mick...
Just remember; an awful lot of the free advice you will get on forums is worth exactly what you paid for it. There will always be somebody trying to convince you to do something really stupid, just because they did it or want to do it.
04-26-2004, 11:56 AM
Formula Extreme Favourite Bike: '98 Triumph Sprint Ex.
Posts: 931 Extra Motorcycle: '02 Kaw Ninja 250
Avatar,
To check that bolt you must pull the alternator and have a look see. It's not a difficult operation, check your manual for instructions. Also, if you look around here you'll find several posts specifically about the alternator bolt problem that really go into detail.
j98
04-26-2004, 11:59 AM
I'd like to add that the alternator bolt problem is quite common.
j98
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Ticking noise Help!
ds6380 |
Speed Triple Forum |
10 |
07-21-2010 03:30 PM |
Ticking Daytona
dogarajo |
Daytona Deliberations |
5 |
01-11-2008 09:34 AM |
engine ticking
katblack |
Tiger Workshop (archive) |
3 |
05-10-2007 02:46 PM |
Ticking Brakes
ExPatTommo |
4 |
11-21-2006 01:39 AM |
ticking noise
hinkleyboy |
Triumph SuperSports |
5 |
09-10-2005 02:56 PM |
