yankee ingenuity - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Old 04-22-2004, 02:19 PM   #1 (permalink)
fyi- getting those nasty epa blanks off and turning out mixture screws only took me a few minutes with an angle drive ratchet mated to a screw extractor and then to a long jewelers bit in a twist lock. Def worth it if you can assemble this tool quickly (it might take you longer then taking the tank and carb bank out if youre not a yankee :-D ). Take the ratchet off and use your fingers to set the mix tho!!
Oh yeah, anyone change out the headlamp reflector on a classic?? the beam pattern does suck for seeing the 20 or so feet of ground between the lamp and where the beam falls.
MC Touring in Gascone - Une Yankee va arriver! Billybob Ride / Trip Reports 0 04-03-2007 07:49 PM
Some good ol' fashioned American ingenuity livefree63 Speed Triple Forum 6 07-09-2006 10:09 PM
Thorough Rocket cleaning & a little ingenuity rusty The Rocket Science Forum 10 06-21-2006 09:56 AM
