Zx6r shock swap - Triumph Forum: Triumph Rat Motorcycle Forums
Old 12-02-2012, 06:51 AM   #1 (permalink)
Main Motorcycle: Triumph Legend
Randommech's Avatar
Zx6r shock swap
Hi all,
I've got a 99 Legend with a 98 t-bird subframe and was thinking about doing the zx shock swap. I was wondering if someone could tell me which year I would need and what kind of improvements to expect from this mod.
Thanks,
RM
Sent from my LGL55C using Motorcycle.com Free App
Randommech is offline   Reply With Quote
Old 12-02-2012, 10:47 AM   #2 (permalink)
Main Motorcycle: '99 Legend / '98 TBS
BigAl8295's Avatar
This thread covers a bunch of the options:
http://www.triumphrat.net/hinckley-c...n-upgrade.html
FCR-39 Carbs, Sprint Cams, British Customs Predator Exhaust, K&N Pod Filters, Nology Coils, Ignitech Ignitor, Progressive Fork Springs, ZX-6R shock, and one bad ass Horn Cover!
Charm City Mods vs Rockers Rally
BigAl8295 is offline   Reply With Quote
Old 12-02-2012, 08:05 PM   #3 (permalink)
Randommech's Avatar
Thanks for the link BigAl
Old 12-03-2012, 03:04 AM   #4 (permalink)
Main Motorcycle: 1999 Legend TT
Hey Random, can you give some insight into the difference between the Legend and the TBS subframes? I've read a lot of conflicting info but I guess they're definitely not the same?
I'm looking for a TBS-like stance on my legend too; I have dogbones on the way but I guess I'll need a subframe too?
Mandres is offline   Reply With Quote
Old 12-04-2012, 01:38 PM   #5 (permalink)
Randommech's Avatar
Wish I could help you but my subframe was swapped before I bought the bike. The only reason I knew it had been done is that Jaguartvr pointed it out to me when I posted some pics to sell my stock turn signals.
You can see what it looks like with one of his fender room kits in my let the winter modding begin thread.
Old 12-04-2012, 01:58 PM   #6 (permalink)
cool, thanks. I'll keep researching and see what I can find.
The problem with the ZX6r shock seems to be that the battery box is in the way of the top-mounted reservoir on the shock. I think Mike said that the box can be mounted sideways to clear it, but looking at mine I'm not sure how that would work.
Since you have the solo seat and cowl another option might be to get one of the new small Lithium batteries and mount it up under the cowl. You'd have to extend the leads obviously, but that could be a good option.
Old 12-04-2012, 04:53 PM   #7 (permalink)
BigAl8295's Avatar
The battery box can be removed, turned 90 degrees and remounted under the right battery cover.
It actually makes it much easier to access the battery.
Old 12-05-2012, 09:55 AM   #8 (permalink)
Do you happen to have a pic of this setup? I looked at mine again but can't visualize how this works.
Old 12-05-2012, 12:04 PM   #9 (permalink)
Main Motorcycle: 99 Legend Sprint GT
IrlMike's Avatar
I haven't seen a pic of Al's set up, but this is how I did it:
http://www.triumphrat.net/hinckley-c...ml#post1945775
I think the ZX6R options are really worth making the space for because the spring rates (& matching damping) are very close to an 'ideal' rate that all the suspension engineers use.
IME the 90 deg battery relocate provides room for the 00-02 6R (& also 9R) Kayaba units. By rotating slightly again on the single mount bolt I used, the later 6R (07/08) Showa with high & low speed compression adjustment can be used (has rebound as well). (Couple of pages on in the above linked thread, you'll see my 08 6R fitted.)
It's also some advantage to use later model shocks as they've generally seen less use. In hindsight the spring on my 01 6R shock was a bit tired when I got it. (Probably seen a few miles on Irish roads lol.)
98 Tbird tank/seat, Sprint fairing, ZX7R forks+Racetech Gold Valves, 08 ZX6R shock, Alcon 6-pot, Ignitech+TPS, T'bike 3-1+Beowolf can, airbox mods/rejet, tubeless wheels, lots :) per mile.
IrlMike is online now   Reply With Quote
Old 12-05-2012, 12:19 PM   #10 (permalink)
Thanks, that's really helpful. I'm going to give it a shot tonight.
I'm stoked at how cheap the late model ZX6r shocks are going for. It looks like a very nice '08-'-10 one can be had for <$50.
Shock Swap rickster Daytona Deliberations 2 06-29-2012 01:27 AM
Squashed ZX6R shock stand63 Hinckley Classic Triples 6 06-20-2012 06:22 PM
My Kawa ZX6R shock swap StrappingLad Hinckley Classic Triples 7 05-01-2012 12:24 AM
99 Adventurer shock swap Brit52 Hinckley Classic Triples 8 06-05-2011 11:16 PM
ZX6R shock ianmac Hinckley Classic Triples 11 04-02-2011 06:22 AM
