Crankshaft Position Sensor - Triumph Forum: Triumph Rat Motorcycle Forums
Old 11-29-2012, 11:39 AM   #1 (permalink)
Main Motorcycle: adventurer
Gentlemen,
I am having the issue when my bike is warm it acts like it is running out of gas. It will cruise at a consistent speed, but under acceleration the rpms drop and the bike struggles. Its a 2000 adventurer with 30000 miles. I think it is the crankshaft position sensor. Where do I buy a new one?
thank you
advhopeful is offline   Reply With Quote
Old 11-29-2012, 01:18 PM   #2 (permalink)
Slinky's Avatar
From a Triumph dealer.
http://www.worldoftriumph.com/
As good as it gets for mail order.
Old 11-30-2012, 10:41 PM   #3 (permalink)
Main Motorcycle: '00 TBS
petermholmes's Avatar
Other Motorcycle: '09 ST3R
Extra Motorcycle: WTB: Metralla GTS
Another really good place to do mailorder business with is Baxter Cycle:
http://www.baxtercycle.com/
They almost always have stuff in stock and will overnight to you if you ask.
Are you sure it's the crank sensor? Usually the adhesive on those gives out and they just fall off, leaving you with *nothing*. Your description sounds more like failing coil to me. Or fuel starvation...
petermholmes is offline   Reply With Quote
Old 12-01-2012, 07:28 AM   #4 (permalink)
Main Motorcycle: 99 Legend Sprint GT
IrlMike's Avatar
Sounds more like a fuel starvation / tank vacuum issue to me ? (..will cruise but not accel...)
Unscrewing the tank cap can determine or eliminate tank vacuum/breathing.
98 Tbird tank/seat, Sprint fairing, ZX7R forks+Racetech Gold Valves, 08 ZX6R shock, Alcon 6-pot, Ignitech+TPS, T'bike 3-1+Beowolf can, airbox mods/rejet, tubeless wheels, lots :) per mile.
IrlMike is online now   Reply With Quote
Old 12-01-2012, 09:58 AM   #5 (permalink)
I am a 100% triumph novice,but mine is held on by 2 torc bolts correct?
Old 12-01-2012, 11:30 AM   #6 (permalink)
Last I knew the pickup coil was glued to the bracket.
I'm with Mike. Once it's started giving you grief, keep riding but unscrew the gas cap until it's loose and see if your problem goes away. If so, the tank vent's plugged.
Old 12-01-2012, 01:06 PM   #7 (permalink)
tried the gas cap trick. If it were plugged wouldn't i hear air rush in I unscrewed the gas cap while the problem was happening to see if it would help but no luck.
Old 12-01-2012, 02:09 PM   #8 (permalink)
Main Motorcycle: 1958 Norton Nomad
Other Motorcycle: 2000 Triumph TBS
Check tha air gap on your sensor. Don't guess at things you'll drive yourself nuts.
Greaser is offline   Reply With Quote
Old 12-01-2012, 02:25 PM   #9 (permalink)
The problem only occurs once the bike is warm? You can give it full throttle when it's cold and it accelerates normally?
Old 12-01-2012, 03:26 PM   #10 (permalink)
IrlMike's Avatar
Well, you've eliminated tank vent, but I still think fuelling (which could include squatters in the airbox etc). When the CPS fails as the engine warms up, the bike will not run at all until the engine fully cools. It's either this mode of failure or complete no-start, don't recall any others reported.
06 Sprint ST Crankshaft position sensor sdkoskey Sprint Forum 3 04-02-2011 10:06 PM
Can 955 crankshaft sensor be tested? CharlestonRider Tiger Workshop (archive) 1 02-23-2010 12:47 PM
Crankshaft positioning sensor, Pickup coil Mattybee Tiger Workshop (archive) 1 10-26-2009 06:49 AM
Throttle Position sensor svbananaman Triumph SuperSports 1 05-02-2007 11:11 AM
Throttle Position Sensor gitaly Twins Technical Talk 14 07-24-2006 04:05 PM
