Does these camshafts fit on my tbs? - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 4 (permalink) Old 11-27-2012, 01:48 PM Thread Starter
Main Motorcycle: Thunderbird Sport, Buell
Red face Does these camshafts fit on my tbs?
http://www.ebay.de/itm/330824616125?...84.m1438.l2648
They are 1999 daytona 955:s Camshafts
If they do fit. and fitted onto my bike what happens? A lot of re jetting and...
If everything done correctly. How much horsepower and torque more?
Jannari is offline
post #2 of 4 (permalink) Old 11-27-2012, 03:18 PM
Main Motorcycle: 2012 Tiger XC
CharlieS's Avatar
Other Motorcycle: My RED '02 Sprint ST
Extra Motorcycle: 99 Thunderbird Sport
Looking at the parts fiche from World of Triumph, the first generation 955 Daytonas and Speed Triples used the same camshafts.
So, according to everything that I've been told, they should fit in your 885 engine.
http://www.worldoftriumph.com/triump...&block_03=3374
http://www.worldoftriumph.com/triump...&block_03=9909
I bought cams from a 2001 Speed Triple for my TBS. 38 teeth on the cam gear.
As far as the hp and torque numbers? I don't know. I haven't done it yet.
I'm getting parts together:
cams
igniter
pod filters
jets
exhaust
I've been told I should be able to squeeze out close to 90 HP at the rear wheel with what I'm going to do. We'll see....
---Charlie
CharlieS is online now
post #3 of 4 (permalink) Old 11-27-2012, 05:21 PM
Main Motorcycle: 99 Legend Sprint GT
IrlMike's Avatar
Note both these camshafts are more agressive than the 'green' cams of the 98hp T3s. The Daytona ones more so than the S3. (Same lift, more duration.)
I posted a pdf before (which I got from here originally) with the details of duration & overlap.
http://www.triumphrat.net/sprint-for...ml#post2345930
Definitely rejetting required, but from what I've seen, air intake mods have at least as much influence on main jet sizing (if not more) as cams.
98 Tbird tank/seat, Sprint fairing, ZX7R forks+Racetech Gold Valves, 08 ZX6R shock, short sw/arm, Alcon 6-pots, Ignitech+TPS, T'bike 3-1+Beowulf can, airbox/jet mods, tubeless wheel mod, lots :) per mile, 55mpg ave(imp)
IrlMike is offline
post #4 of 4 (permalink) Old 11-27-2012, 10:38 PM
Main Motorcycle: 02 Centennial Daytona
Other Motorcycle: 04 Speedmaster
Extra Motorcycle: Pink 50
Spoke with my local dealer a few weeks ago about this. They gave me a dyno sheet and a long story about a TBS. Yes they will fit is the short. The long answer is that they used the 955 daytona intake cam but swapped in a T509 green exhaust cam to gain back a little midrange. I'll see if I can find the sheet, but I'm sure it was 87hp when finished with a nice curve.
Aunatural is offline
Camshafts (again) lovecuba Classic, Vintage & Veteran 2 11-17-2012 05:28 PM
ACL camshafts dwornik Speed Triple Forum 0 07-17-2012 02:02 AM
98 TBS camshafts. tbspete Hinckley Classic Triples 4 01-09-2011 05:37 PM
camshafts steveboy Air Cooled Twins Technical Talk 28 03-23-2010 08:02 PM
Camshafts Flatrack Classic, Vintage & Veteran 3 08-19-2004 07:45 PM
