11-25-2012, 06:23 PM
Production 125 Main Motorcycle: Yamaha FJ1100
Posts: 10 Other Motorcycle: Commando 850 Extra Motorcycle: T160
Help with Carbs!
Hey folks,
I am working on a buddy's 96 Tunderbird 900
The bike was badly neglected over the last 16 years -- it has 1.600 miles, and spent long periods -- years -- without any use.
I cleaned the carbs (and intalled new float needles and gaskets and o rings), and reinstalled them. Hooked them up to a remote, gravity feed tap/tank from my 75 Commando, as the T900 tank is badly rusted and I am not finished cleaning and sealing it.
Fired up pretty quickly and ran strong for about 5 minutes, then slowly died out and would not restart. I heard a gurgling sound from the airbox while it was running (which I had cleaned out when I reintalled the carbs.)
Is the vacuum line to the tap (which I did not block off) screwing up the fuel flow?
Duck bill was clear (at least, I could blow air through the fuel intake), at least when I fired her up.
11-25-2012, 08:14 PM
Site Supporter Team Owner Main Motorcycle: 99 Legend Sprint GT
Vacuum line to the tap?
The stock Tbird has a manual fuel tap, no vacuum operation.
98 Tbird tank/seat, Sprint fairing, ZX7R forks+Racetech Gold Valves, 08 ZX6R shock, Alcon 6-pot, Ignitech+TPS, T'bike 3-1+Beowolf can, airbox mods/rejet, tubeless wheels, lots :) per mile.
11-26-2012, 03:44 PM
Grand Prix 250 Main Motorcycle: 04 Thunderbird
could the gurgling noise be flooding?
11-27-2012, 06:25 AM
Didn't smell any gas. None.
Maybe the crankcase vapor hose?
Going to dive back into it later this week.
I see that these did not come with vacuum feed petcocks in stock form. Though for sure I disconnected a second line from the petcock, I will go back and check what i was thinking there.
(Why on earth did they design this bike so you have to pull the carbs to change the air filter, btw???)
11-27-2012, 01:08 PM
Site Supporter Team Owner Main Motorcycle: 98 Thunderbird
Posts: 4,544 Other Motorcycle: 03 Speedmaster
The second line is probably the overflow that fits to the rear of the T-bird tank. It might be an idea to check for a spark when it heats up, could be something getting hot and failing, i.e the pickup coil or ignition coil, but 5 mins is probably not long enough for that to happen.
11-27-2012, 09:32 PM
Supersport 400 Main Motorcycle: Triumph Thunderbird
Originally Posted by Tom Renda
Hey folks,
Get it running on the remote, and then when it starts to idle down, turn the petcock off and hold the rpms up for 20 seconds or so with the throttle. If she idles clean with the petcock off, but the problem comes back when you turn the gas back on, it's the floats / float valves / o-rings (which you replaced, but I replaced mine a month ago and she's doing it again. If you used the GSXR rebuild kit, the o-rings are just a hair thick, which seems to cause problems in the short term.)
Merlyn
11-28-2012, 12:40 AM
SuperBike Main Motorcycle: my 1999 triumph legend
Adjusting the float levels on these is a bit of a pain. Don't know about the Mikunis, but with the Keihins you let the tab touch the little nipple that compresses, but don't let it compress.
You can test them for flooding on the bench as well, by hooking up your fuel line to each one individually, and letting the gas into the float bowl and then see if it begins leaking by.
I have found even the tiniest bit of rust specks are enough to mess up the needle valve or the jets, so if there is any possibility that any sediment could have gotten into the carbs (possibly dried up in the fuel lines and then reconstituted when the fuel went through the line?), it could be the problem. Put a clean hose on the fuel bowl drains and drain them onto a white paper towel. Any gunk will be visible.
11-28-2012, 05:30 PM
Merlyn
crap i did use the gsxr kits cause they were cheap!
12-04-2012, 05:32 PM
Same here- did you ever get it sorted?
Merlyn
12-10-2012, 01:10 PM
a slightly cracked vacuum line has been enough to keep my engine from starting in the past. Quick trip to autozone and a couple snips later had me good as gold again. here's to hoping it is a simple a fix for you.
