neutral switch, clutch switch - Page 2 - Triumph Forum: Triumph Rat Motorcycle Forums
Old 11-17-2012, 12:21 PM   #11 (permalink)
Main Motorcycle: adventurer
No power to the solenoid. the N light dims when I hit the start button, but that is all i get. The bolt I see is in good shape.
advhopeful is offline   Reply With Quote
Old 11-17-2012, 01:03 PM   #12 (permalink)
Main Motorcycle: 99 Legend Sprint GT
IrlMike's Avatar
Find out which side, ground (yellow/gree) or + of the solenoid coil isn't getting fed. Ground goes thru' the clutch/neutral switches, + comes from the ign switch & cut out switch & a fuse. Connect a meter to either side of the battery & the other to one of the terminals.
If you haven't got a wiring diagram, search on this forum on that term & you'll find the one I posted yonks ago.
98 Tbird tank/seat, Sprint fairing, ZX7R forks+Racetech Gold Valves, 08 ZX6R shock, Alcon 6-pot, Ignitech+TPS, T'bike 3-1+Beowolf can, airbox mods/rejet, tubeless wheels, lots :) per mile.
IrlMike is online now   Reply With Quote
Old 11-17-2012, 02:17 PM   #13 (permalink)
so I tracked the power and the 2 prong round metal box that is the first place the power goes was where the power stopped I unbolted the wires touched them and bam starter action. Could this part be my problem? What is that part called?
Old 11-17-2012, 02:58 PM   #14 (permalink)
IrlMike's Avatar
That's the starter solenoid. If you need a new one, I've used a generic one for Honda off ebay (new), fits in the Triumph rubber mount & is much cheaper.
Old 11-17-2012, 05:54 PM   #15 (permalink)
Is there a way to test it?
Old 11-17-2012, 06:35 PM   #16 (permalink)
IrlMike's Avatar
You could apply 12v to the small terminals & see if it will operate the starter? (Did you confirm + & ground feed to those terminals earlier?)
Old 11-23-2012, 06:08 PM   #17 (permalink)
Main Motorcycle: Triumph Sprint
This sounds very familiar.
In the end I found that the wiring harness was faulty just below the ignition switch.
I replaced the faulty section and all my problems went away .....
Make sure you have no evidence of harness "rubbing" against the frame in places you would normally no look...
Also, some years ago, I foolishly put too much graphite into my key ignition...,
got all the "go" lights put nothing happened when I pushed the starter.
obmwk75c is offline   Reply With Quote
Neutral Switch Grp914 Sprint Forum 11 07-18-2010 10:59 PM
Neutral switch Flying Custard T3 Sport / Touring Forum 6 04-14-2010 06:40 AM
Clutch, Neutral Switch & Starting. grrrr! datapimp Hinckley Classic Triples 3 08-04-2008 08:18 PM
Neutral Switch dynam Maintenance & Workshop Talk 1 06-11-2007 08:04 PM
Where's the neutral switch? smithtt Triumph SuperSports 4 11-02-2006 12:55 PM
