Thunderbird Sport not starting in the cold? - Triumph Forum: Triumph Rat Motorcycle Forums
Old 11-14-2012, 05:54 PM   #1 (permalink)
Main Motorcycle: Thunderbird Sport
I just learned something new about my TBS that I thought I would share. I've always thought it was pretty bad at starting in cold weather. I always opened the choke fully and pressed the starter. But, I have just found out that it starts much better if you don't open the choke all the way. Hope it helps if you have the same problem.
rogoff is offline   Reply With Quote
Old 11-14-2012, 10:26 PM   #2 (permalink)
Main Motorcycle: 1999 T'Bird Sport
lovecuba's Avatar
Extra Motorcycle: 1977 T140
Choke (Enricher)
Ditto, never use mine for starting, but for a high idle when 'getting dressed' for the ride, invaluable!
lovecuba is online now   Reply With Quote
Old 11-15-2012, 08:42 AM   #3 (permalink)
Main Motorcycle: My TBS of course
zimtok's Avatar
UMMM.....
Just to clarify when you apply the choke you are closing it not opening it.
When I'm starting my TBS in cold temps I put the choke at full and start cranking then immediately start opening it a little as I continue.
The engine starts within just a couple revolutions and I adjust the choke to keep it running at just above 1000rpm to warm it up.
My life is based on a true story.
www.throttlejockey.co.uk
zimtok is offline   Reply With Quote
Old 11-15-2012, 11:25 AM   #4 (permalink)
WSC
Main Motorcycle: T150V
Other Motorcycle: '04 Thunderbird Sport
Extra Motorcycle: Thunderbolt
Originally Posted by zimtok View Post
UMMM.....
Actually, these carbs don't have a choke, per se. They have a cold enrichment valve which adds fuel for a richer mixture and a little air for a faster idle. Turning the "choke" "on" opens the valve.
John
Laconia Bike Week 2013
2004 Thunderbird Sport
1975 T150V
1968 BSA Thunderbolt
WSC is online now   Reply With Quote
Old 11-19-2012, 07:09 AM   #5 (permalink)
Main Motorcycle: 2000 Thunderbird Sport
Cyclepath's Avatar
Other Motorcycle: 2010 R1200GS 30th aniv.
Extra Motorcycle: 2006 Triumph Scrambler
WSC is correct, it is simply an en-richer circuit. My TBS starts perfectly using the full en-richer to start, then I back if off to the point of a slightly elevated idle speed for a few minutes as I ride off.
If your's doesn't start correctly using full en-richer, and in fact starts better when you only use part of it's enrichment, it would seem that either your low speed jet is too large, or your idle mixture screws are set way too rich, or a combination of both??
Cyclepath is offline   Reply With Quote
Old 11-19-2012, 08:43 AM   #6 (permalink)
zimtok's Avatar
Really...
I guess I learned something today...
I'll have to take a closer look at my carbs next time I have them off.
Old 11-19-2012, 03:09 PM   #7 (permalink)
Slinky's Avatar
Same here..
Old 11-19-2012, 08:21 PM   #8 (permalink)
WSC
No disassembly required. Just look to see what moves when you move the "choke" lever.
John
1975 T150V
Old 11-19-2012, 10:23 PM   #9 (permalink)
Main Motorcycle: daytona 675
hmm...
Cody Strife is offline   Reply With Quote
Old 11-19-2012, 10:26 PM   #10 (permalink)
I seen bonnevilles that are fuel injected yet have a choke. do they mechanically do anything at all, or do they simply open and close contacts?
Jump Starting and cold cold temps ztolley The Rocket Science Forum 25 06-04-2013 02:19 AM
need some basic info on the Thunderbird/Thunderbird Sport ohiorider Hinckley Classic Triples 23 12-06-2010 11:49 AM
Cold Starting T-100 dgreene Twins Technical Talk 14 02-27-2010 06:41 AM
Starting from cold slunker Triumph SuperSports 4 05-14-2009 07:27 PM
cold starting kdrake Twins Talk 9 01-14-2006 08:45 AM
