brake master cylinder - Triumph Forum: Triumph Rat Motorcycle Forums
Old 11-05-2012, 04:42 PM   #1 (permalink)
l am drilling out the screws on the master cylinder and hope to remove them and replace with new screws. lf l fail, anyone know of a non triumph master cylinder that might improve the braking and is straight fit.
thekeyman is offline   Reply With Quote
Old 11-06-2012, 10:55 AM   #2 (permalink)
WSC
Main Motorcycle: T150V
Other Motorcycle: '04 Thunderbird Sport
Extra Motorcycle: Thunderbolt
If you can get your hands on the right screw driver (JIS, not Philips) you might not have to drill anything...
John
2004 Thunderbird Sport
1975 T150V
1968 BSA Thunderbolt
WSC is offline   Reply With Quote
Old 11-06-2012, 01:54 PM   #3 (permalink)
Slinky's Avatar
A m/cylinder from a Suzuki GS500 or Kawasaki Ninja 500 will work and it looks very similar. Just make sure it's from a naked bike and not a faired bike, the latter may not have a mirror mount.
Also make sure it is a 1/2" bore master cylinder, some (with double discs) will be 14mm. The stock Triumph part is 11mm bore.
Brake master cylinder Axconis Speed Triple Forum 4 12-05-2011 05:46 AM
Changing Brake Master Cylinder/Brake Lines dennisg Classic, Vintage & Veteran 3 11-15-2011 07:41 PM
S4 Ft Brake Master Cylinder HELP! sr9004u Triumph SuperSports 4 12-20-2007 05:33 PM
Brake trouble, anybody else rebuilt the front brake Master cylinder uzidzit Twins Technical Talk 3 10-13-2007 12:55 AM
