Replacing the back tire - broken part - what's it called? - Page 2 - Triumph Forum: Triumph Rat Motorcycle Forums
Old 11-06-2012, 11:12 AM   #11 (permalink)
WSC
Main Motorcycle: T150V
Other Motorcycle: '04 Thunderbird Sport
Extra Motorcycle: Thunderbolt
Improper assembly?
The only way I can see it would crack is if it was installed against an uneven surface. How it would get uneven in the first place remains a mystery...
Unless somehow the crack originates at the index mark...
John
2004 Thunderbird Sport
1975 T150V
1968 BSA Thunderbolt
WSC is offline   Reply With Quote
Old 11-06-2012, 01:37 PM   #12 (permalink)
Slinky's Avatar
The collar is shaped to fit into the slot in the swingarm, it is possible to assemble it wrongly so that there is undue stress on the collars, that would also cause the indentations on the swingarm slots.
Slinky is online now   Reply With Quote
Old 11-06-2012, 01:46 PM   #13 (permalink)
Main Motorcycle: Speedtriple!!
triplestrength's Avatar
Other Motorcycle: Triumph Trophy 900
Extra Motorcycle: Honda CB400AT
Imagine this.
Previous owner trying to remove spindle thats a bit stuck, uses pry bar levering against this piece and breaking it.
Or mechanic replacing tyre the other day doing it?
Sent from my GT-I9100P using Motorcycle.com Free App
triplestrength is online now   Reply With Quote
Old 11-06-2012, 09:29 PM   #14 (permalink)
Main Motorcycle: Triumph Thunderbird Sport
Brian C's Avatar
Other Motorcycle: 2010 Speed Triple
Pics of the broken part
Well I dropped off the part at the shop and they put it on. Rode the bike home with no problem. I did not ask if they closely inspected the swing arm but am confident they would have said something if there was a problem. I will take a good look at it tomorrow in the day light. I suspect that the last mech that worked on the bike over torqued the lug at last tire change and cracked it but the lug held it tightly in place...thankfully! I often ride on the interstate at high speed (70mph +). You can see in the two pics I posted that it's simply split in half and the exposed metal is rusted so it's been like that for awhile. I think I just got a bye on this one.
Replacing the back tire - broken part - what's it called?-2012-10-30_14-48-20_574.jpg   Replacing the back tire - broken part - what's it called?-2012-10-30_14-48-32_255.jpg
Brian C is offline   Reply With Quote
Old 11-06-2012, 09:35 PM   #15 (permalink)
Brian C's Avatar
I don't know if the the forum allows for maintenance alerts on the TBS, but I think this may be worthy. Any one with a TBS or other motorcycle that uses the same part should be notified to do an inspection soon. I can only imagine what would happen if this part came out while underway at highway speed. I think the bike would literally come apart. Can someone notify the site administrator please.
Old 11-06-2012, 10:11 PM   #16 (permalink)
Main Motorcycle: Honda Valkyrie
Other Motorcycle: Triumph Thunderbird Sport
Oh snap... that is scary stuff!!
Thanks for posting pictures. I'll be sure to check mine!!
CajunRider is offline   Reply With Quote
Old 11-06-2012, 10:31 PM   #17 (permalink)
Main Motorcycle: 2012 Speedie
steve.g's Avatar
Other Motorcycle: 2002 Sprint RS
Extra Motorcycle: Yamaha xs650
I've seen them break. It's usually caused by over tightening of the axle nut and / or incorrect wheel alignment because the chain isn't adjusted right. Worst case scenario ... block breaks , falls out and you get a really scarey wobble that could put you down. I doubt the axle would fall out or break because you would know something was wrong way before then.
Over the hill and picking up speed on the way down...!!!
steve.g is offline   Reply With Quote
Old 11-07-2012, 08:48 PM   #18 (permalink)
I will definitely keep that in mind.
I usually just give the axle nut a good pull with a 2 ft. long wrench (1/2" socket drive). I'm going to have to put a torque wrench on it one day to see how much I've been over tightening all this time.
'09 Thruxton won't start after replacing broken clutch lever man_in_black Twins Technical Talk 8 08-18-2012 07:58 AM
broken part, what is it? Maxcap75 Hinckley Classic Triples 8 06-06-2011 06:44 AM
The British called - They want their guns back! Skull Crusher Biker Hang-Out 82 05-09-2009 08:44 AM
Broken bike part 2 not Happy!!! Bundyon_Jen Sprint Forum 12 09-11-2006 04:49 PM
Need help naming/replacing part suckaplease Classic, Vintage & Veteran 5 02-11-2006 10:39 PM
