T-Bird triple wont rev over 4500? - Page 3 - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.com Motorcycle.com Classifieds!
Old 09-18-2012, 03:44 AM   #21 (permalink)
Main Motorcycle: Triumph Legend
Randommech's Avatar
Thanks for posting that link Denny, ya beat me to it. That duckbill filter is quit inconspicuous and I never knew it existed till I stubled upon that thread. Just goes to show the wealth of knowledge other members have on these great bikes. This forum rocks :beer::beer::beer::beer::-):sly:
Sent from my LGL55C using Motorcycle.com Free App
Randommech is offline   Reply With Quote
Old 09-18-2012, 01:22 PM   #22 (permalink)
WSC
Main Motorcycle: T150V
Other Motorcycle: '04 Thunderbird Sport
Extra Motorcycle: Thunderbolt
Originally Posted by ArferBrick View Post
OK, I think I'm getting closer now -
So by "air flow" surely you mean "air volume",
I mean volume per unit time. Maybe I should call it "flow rate"???
And "constant velocity" would mean that the speed of airflow over the needle Jets should remain the same at (for the sake of argument), all engine speeds I would imagine.
Yes. This type of carb is often called a CV carb,or Constant Velocity. The CV part only applies to the main circuit, though; the pilot circuit, pilot screw and transition ports are no constant velocity.
Therefore if the velocity (speed of airflow) remains the same, then the volume of air at that given velocity must increase to supply the demand of the engine - correct?
Correct. And, that cannot happen unless the size of the passage increases, which is what happens when the slide rises. If the cross sectional area were to remain the same then the velocity must increase if the flow rate is to increase. Greater velocity results in reduced pressure. (This is how a "conventional" carburetor works).
And to meet that demand the slides rise, creating a wider hole for the air to go through, thereby keeping the velocity the same?
Oh, I see you already said that...
I'm not trying to be a smart arse, or cause argument, I'm very interested in how these things work. It could help me immensely in the future, and every bit of knowledge helps.
Absolutely not! It is "counter-intuitive".
John
Laconia Bike Week 2013
2004 Thunderbird Sport
1975 T150V
1968 BSA Thunderbolt
WSC is offline   Reply With Quote
Old 09-18-2012, 04:23 PM   #23 (permalink)
Main Motorcycle: Own a 95 Super111.96 Tige
threepot's Avatar
Other Motorcycle: 96 black Tiger. 73 CB125
Extra Motorcycle: None
Hi guys,can you throw some light on this?,recently bought 96 Tiger. Bike was cutting out after about 3 miles..traced that to blocked carb inlet filter. But now it runs poorly at low revs..hesitant,but clears when i open throttle to accelerate.Not sure if this was before clearing filter,didnt ride it far b4 buying..mistake!New plugs fitted. Noticed it has k&n air filter and std silencers.Have recently cleaned carbs,checked float heights,checked pilot screws..seems to be flat spot under hard acceleration now? Thanks
threepot is offline   Reply With Quote
Old 09-18-2012, 08:52 PM   #24 (permalink)
Main Motorcycle: 1979 T140E
Other Motorcycle: 1976 KZ400D twin
Extra Motorcycle: 1997 Triuph Thunderb 900
Yes I have seen those but did not check it on my clean out, thanks.
Autotek is offline   Reply With Quote
Old 09-19-2012, 03:57 AM   #25 (permalink)
Main Motorcycle: '96 Adventurer
ArferBrick's Avatar
Other Motorcycle: Yamaha TDR 125
Here's what I'd do -
Check the colour of the plugs, this usually gives a good indication of what's going on. Black & sooty means too rich, white means too lean. Black and oily is an ignition problem. They should all look roughly the same colour. If not then the odd one out is the problem cylinder/carb.
Check the carb rubbers and complete primary airbox for leaks, when the PO installed the K&N he or she could have put it back together badly, maybe put some silicone in the joint (there's only one). Oh and make sure both of those hoses underneath are connected too, the breather hose and the overflow hose.
Pull the carbs out again and change the tiny 3mm O-Rings in the idle screw holes, they should also have a metal washer that sits between them and the spring. If it's not there, buy new ones. Set the screws to 2.5 turns out.
EDIT - another thing to watch out for is a second rubber or washer stuck in the idle screw holes, make sure they are empty before re-assembly in the order - O-Ring, metal washer, spring, idle screw. You can also stretch the springs a little to give them more strength, and lubricate the thread to avoid serious problems in the future!!
Change the O-Rings under the throttle slides , they're cheap as chips but can cause big problems.
Clean the idle jets thouroughly, and make sure you can see through them and that the holes are clear. Use a piece of brass wire to clear any blockages.
Check the throttle slides for correct operation, they should rise and fall easily and smoothly. If there's resistance - something's wrong. Maybe not relevant in your case as they are high speed related, not idle, but while you're in there you might as well.
Check the choke plungers for correct and free operation, are they closing properly? Pull the springs a bit to make them a bit longer, this gives them more "closing strength" I've found. And lubricate the shafts.
Check the idle air inlet jets at the rear of the carb - they are the ones in the RHS hole that are removable, the LHS holes are emulsion tube air inlet jets and are fixed but should also obviously be clear.
Look at the throttle butterflies to see if anything is awry. They should all look the same, apart from that I can't describe any known problem. You might look for odd staining on the wall of the carb, that could indicate an air leak from around the throttle shaft.
Balance the carbs. She aint gonna run too well if the carbs aren't balanced. You'll either have to have your own tool for this or take it to a garage. If you're going to buy your own I recommend the Morgan Carbtune Pro, it's cheap and works really well.
You said you checked the float height, not sure how you did it, but this is how I do it. Remove the float bowls and rotate the carbs so that the floats move from the open (sitting low in the float bowl) to closed position (sitting high up in the carb body). Do it a few times and when you see that they reach the closed position (you'll see them stop moving as the carbs continue to rotate, should be at about the 60° point), stop rotating - the floats have a line along their mid section, that should form a parallel line with the base of the carb.
As long as they look near enough parallel, you're good to go. Again, they're not going to affect the idle performance, so I shouldn't worry too much.
The only thing that's going to cost you money is the O-Rings (cheap as), and the balance tool if you don't have one (a bit expensive, around the 60 - 70 euro mark).
Here's everything I have that's carb related -
http://christiane.homeip.net/pub/adv...ebuild-part-1/
http://christiane.homeip.net/pub/adv...ebuild-part-2/
http://christiane.homeip.net/pub/adventurer/carbs/
http://christiane.homeip.net/pub/adventurer/2012-09-09/
http://christiane.homeip.net/pub/adventurer/2012-09-08/
http://christiane.homeip.net/pub/adventurer/mikuni/
Apart from that I have no more ideas
Hope it works out .
ArferBrick is online now   Reply With Quote
Old 09-22-2012, 03:28 PM   #26 (permalink)
threepot's Avatar
Thanks for your reply, I balanced the carbs..aswell as I could,bike does run without hesitation,but idles at 1500k and is slow to rev down. Idle adjust makes no diff?? Im hoping to borrow a set of Davida guages,will try those. Also,noticed that intake ducts are straight thru? Have posted Q on Tiger forum about that? Could K&N be prob? ps,new plugs fitted,and intake rubber boots.
Performance otherwise is excellent. Bike pulls llike a train.
Old 11-14-2012, 07:17 AM   #27 (permalink)
Update, this motorcycle is no longer a part of my life.
Old 11-14-2012, 03:03 PM   #28 (permalink)
Main Motorcycle: '98 Thunderbird Sport
denny's Avatar
Other Motorcycle: '06 Husqvarna TE 610
Extra Motorcycle: '95 TBird - Project
I am so sorry for you
Cheers,Denny
denny is online now   Reply With Quote
Old 11-14-2012, 05:28 PM   #29 (permalink)
Do not cry for me, I still have a 79 Bonneville in restoration.
2007 speed triple wont start! dc4life Speed Triple Forum 27 02-26-2012 10:25 PM
06 Speed Triple wont start redt595 Speed Triple Forum 8 07-20-2011 01:02 AM
05 triple wont start *** tracktriple05 Speed Triple Forum 4 06-16-2009 09:30 PM
FS: 2000 Speed Triple San Diego $4500 nyburner Speed Triple Forum 1 08-22-2006 02:33 PM
T-bird Sport wont start after soaking rain morecarl Hinckley Classic Triples 7 11-05-2005 10:56 PM
