Adjusting valves on Legend - Page 3 - Triumph Forum: Triumph Rat Motorcycle Forums
Old 08-17-2012, 06:46 PM   #21 (permalink)
Main Motorcycle: '97 Thunderbird 900
Waspjunior's Avatar
Smile
@ WSC you've just put me off buying a Continental engined Beech Bonanza. Maybe I can have that Vincent Black Shadow now!
Just got to win the lottery!
Waspjunior is offline   Reply With Quote
Old 08-17-2012, 07:27 PM   #22 (permalink)
WSC
Main Motorcycle: T150V
Other Motorcycle: '04 Thunderbird Sport
Extra Motorcycle: Thunderbolt
Originally Posted by WSC View Post
Aircraft mechanics have all sorts of offset gizmos for torque wrenches. The crow's foot is just the easiest one to find a picture of. (And the one I use to torque the head on the T150...)
Originally Posted by LakeRat View Post
Whith all of the kinks and bends on those extensions what kind of math would you have to do to figure out the actual torque?
Actually, none. If you look closely, you'll see that the point where the torque wrench attaches is directly in line with the point the tool attaches to the fastener. No lever arm.
If you're using a short extension, a good trick is to have the extension at 90* to the torque wrench so, again, no correction is needed.
Hmmm, the Bonanza may be less expensive in the long run...
John
2004 Thunderbird Sport
1975 T150V
1968 BSA Thunderbolt
WSC is offline   Reply With Quote
Old 08-17-2012, 09:39 PM   #23 (permalink)
Main Motorcycle: '98 Thunderbird Sport
denny's Avatar
Other Motorcycle: '06 Husqvarna TE 610
Extra Motorcycle: '95 TBird - Project
These drawings were posted here quite some time ago.
I do not know who was the original author.
Some folks at the time did use these drawings to make their own tool for removing the shims.
Cheers,Denny
denny is offline   Reply With Quote
Old 08-19-2012, 11:19 AM   #24 (permalink)
Main Motorcycle: '96 Adventurer
ArferBrick's Avatar
Other Motorcycle: Yamaha TDR 125
Cool, thanks Denny.
Now I just have to translate those funny Heiroglyphs into modern measurements and I'm good to go .
ArferBrick is online now   Reply With Quote
Old 08-20-2012, 12:08 PM   #25 (permalink)
Main Motorcycle: 1995 Thunderbird
triumphjan's Avatar
Other Motorcycle: Thunderbird Sport 1998
Extra Motorcycle: Estrella BMW R 26
@ Anyone got any pics of the shim tool in action, I might have a go at building one myself.
@Now I just have to translate those funny Heiroglyphs into modern measurements and I'm good to go
Groet Jan.
triumphjan is offline   Reply With Quote
Old 08-20-2012, 12:14 PM   #26 (permalink)
triumphjan's Avatar
Old 08-20-2012, 09:31 PM   #27 (permalink)
WSC
So, the whole point is to keep the spring compressed while the cam moves away, allowing the shim to be removed?
John
1975 T150V
Old 08-21-2012, 12:55 AM   #28 (permalink)
denny's Avatar
yup! ...
Cheers,Denny
Old 08-21-2012, 07:11 AM   #29 (permalink)
Main Motorcycle: 99 Legend Sprint GT
IrlMike's Avatar
Class write-ups, pics & diagrams from denny & triumphjan!
98 Tbird tank/seat, Sprint fairing, ZX7R forks+Racetech Gold Valves, 08 ZX6R shock, Alcon 6-pot, Ignitech+TPS, T'bike 3-1+Beowolf can, airbox mods/rejet, tubeless wheels, lots :) per mile.
IrlMike is offline   Reply With Quote
Old 11-08-2012, 07:05 PM   #30 (permalink)
Main Motorcycle: '99 Triumph Adventurer
Other Motorcycle: '91 Honda XR250L
I was just researching valve adjustment, and found comments in here about using an allen wrench to remove and retorque the cap bolts. I wanted to add a tip about that.
Torque is just a particular force acting at a particular distance from the fastener being torqued. It is defined as acting at a right angle. So, you can combine an allen wrench (or any other kind of wrench) with a fish scale and end up with a torque wrench. Here's how (I'm using foot pounds but for metric guys the same principles apply).
I have a fish scale, a spring device that reads up to 50 pounds. Say you have a wrench you want to use on the fastener, and it is exactly one foot long between centers (imagine the center of the bolt being turned and measure from there, up to the place the fish scale is going to be hooked on - not the overall length of the wrench). If the torque setting is 20 pounds, all you have to do is hook the fish scale on the end of the wrench, at an angle of 90 degrees from the wrench, and pull until the fish scale reads 20 pounds.
Well, what if the wrench is 7.3 inches between centers, not 12 inches? Obviously you have to pull harder because you have less mechanical advantage. The factor would be 12/7.3, so the reading on the fish scale should be 12/7.3 times 20, or about 33 pounds, to apply a torque of 20 pounds.
What if the torque setting is 70 pounds, more than the fish scale reads? Then what you want to do is lengthen the wrench (using a cheater bar or a vice grip) to give you more mechanical advantage, so you have to pull less. Say your lengthened wrench is 17 inches long between centers. The factor would be 12/17, so the reading on the fish scale should be 12/17 times 70, or about 49 pounds.
Make sure your fish scale is reasonably accurate. Always try to get the angle 90 degrees to the wrench; eyeballing it is good enough.
I use this method at least as much as a conventional torque wrench. It is easier to carry a fish scale in your tool box than a torque wrench. Also works well in small toolkits. There have been times I have torqued an oil drain plug in a car without a lot of room underneath, by hooking a coat-hanger wire to the wrench and pulling that with the fish scale.
Getting back to the valve adjustment, I wonder if most people just buy the tool? Camshaft removal looks like a pain. Also it's good to read I might be able to get by without silicone, which to me sounds crazy to use in an engine.
I was looking at the coolant change too. The shop manual calls it a "permanent" coolant. It also calls for changing every two years in the maintenance chart. It also calls for changing it every 18k miles or 6 years in the same chart. Anyone got an idea? Should I just go to the dealer for the right coolant?
PaulBx is offline   Reply With Quote
Triumph 250 need help adjusting valves. 78BritBastard Classic, Vintage & Veteran 3 02-28-2011 03:34 PM
Need help adjusting valves HoyaXC07 Sprint Forum 2 06-12-2009 09:23 PM
Shim Kit for adjusting valves JTXR Sprint Forum 11 05-26-2008 01:32 AM
adjusting valves martingilly Hinckley Classic Triples 3 08-14-2006 11:52 PM
adjusting your own valves? Difficult? roadkill Speed Triple Forum 6 11-28-2005 11:48 PM
