>>Thanks for the post, but I am monitoring the spark with a spare plug grounded out to the engine casing, and have swapped wires and coils. My #3 coil and wire fire the #2 cylinder, thats why I suspect the Igniter. Would a Lilly chip take the place of the igniter or is it in line?<<
Check the wiring between the igniter and coil. You could have a bad connector or connector pin (burnt, loose, bent, etc.) so that's worth a careful examination. A bad crimp on a connector pin is another possibility. If the wiring is healthy then It's probably like the igniter since you've swapped coils and the problem didn't move.
It's pretty unusual that an igniter like this fails with an intermittant, so do check the wiring and connectors carefully.
Try
www.baxtercycle.com for a used replacement at 1/2 or 2/3 list price. (I don't remember their used parts pricing policy.)
FYI: The later Classic triples use a sealed (non-repairable) Gill transistor ignition. It is not a CDI (Capacitive Discharge Ignition), not reprogrammable, does not have a replaceable "chip" and isn't an ECU (Engine Control Unit) since they're only found on fuel injected vehicles.
Jim
