The inlet rubbers are located on the front of the carburator, when you are sitting on the bike, they connect the carbs to the engine. from what I know the Thunderbird has restriction on these rubbers compare to the TBS. Fitting the TBS rubber will get rid of that restriction.
For your popping, normally the carbs are too lean. It is only a matter of opening the mixture screw, located under the carbs, sometimes capped. With off road pipes, you can put them about 21/2 turn out from close and you will get rid of a lot of popping. Mind you a little is nice.
In doubt, crank the throttle.
