Motorcycle.comBikeBanditAdvanstarMotorcycleShows
BikeBandit
Old 11-15-2005   #1 (permalink)
Hi Folks
Does anyone know if there's a product out there to extend lines from the battery terminals out to the side to make charging a battery easier? The seat on my 2001 Legend is a pain in the --- to get off so I can reach the battery terminals. If the right side cover is removed one terminal post is right there - but the other can't be reached. I would think these would be available - even a generic type?
Legendman is offline   Reply With Quote
Old 11-15-2005   #2 (permalink)
Most of the trickle chargers like "battery tender" have a lead you leave onthe bike and tuck under the seat as you have described.
By far the second worst design on these bikes is the seat release? You need a tool to get to the tools! (First worst being the Air Box!) :hammer:
Patrick http://www.click-smilies.de/sammlung...smiley-083.gif
"I'd rather have a bottle in front of me than a frontal labotomy."
whodatpat is offline   Reply With Quote
Old 11-15-2005   #3 (permalink)
However you will need to remove the seat from time to time to check the water level ( at least every 3 month) and eventually refill..
T300 batteries are sensitive to boiling due to the high output from the alternator..
BTW easy removing from the saddle is not a big issue, yo have 2 options.. buy gold plated screw for $$$$ or the Dick and knife approach for a few cents
[ This message was edited by: legend21 on 2005-11-15 13:05 ]
legend21 is offline   Reply With Quote
Old 11-15-2005   #4 (permalink)
Favorite Bike: 06 Sprint ST ABS
Garyhjd's Avatar
Other Motorcycle: Legend TT
ok legend21,
thats pretty trick, so pony up with bigger pics and instructions on how you made those things. I guess I could figure it out, but I really don't want to work that hard :razz:
gary
Garyhjd is offline   Reply With Quote
Old 11-15-2005   #5 (permalink)
Favorite Bike: 96 Thunderbird
Other Motorcycle: 96 Tiger
I found that I don't actually have to remove my battery to fill the cells. After taking the seat off I can remove the strip of caps on top of the battery and fill each cell with distilled water using a dropper and "guestimating" the correct level. Does anyone know if overfilling the battery would hurt it?
Paul
tacomaguy is offline   Reply With Quote
Old 11-15-2005   #6 (permalink)
Gary
If you don't want to work that hard Then buy the gold platted stuff available for $$$ It will easier for you
Paul
However you have to remove the saddle , which is not locked on legend and late tbird but screwed.
Old 11-15-2005   #7 (permalink)
Paul
Overfilling the battery doesn't necessarily "hurt" it, it just isn't good practice. Doing it your way it would be best to stop short of the full level on each based on the marks you can see on the outside of the battery.
Excess fluid is drained overboard through a plastic tube, you will want to ensure this tube is routed correctly straight down so that no battery acid gets on your bike when it vents.
Bob
My Photo Album
bobshields55 is offline   Reply With Quote
Old 11-16-2005   #8 (permalink)
I have my TBS connected to an Optimate, there is a permanent lead in with the kit with a waterproof end which I have tywrapped to the frame, so quiet easy to disconnect as req
lancashirelad is offline   Reply With Quote
Old 11-16-2005   #9 (permalink)
Wife has a 99 legend......and you are right it is a pain, so I attached 2 leads to the battery and ran them behind the chrome cover on the right side of the bike. Seems to work good for me.
triumphrider99 is offline   Reply With Quote
Old 11-16-2005   #10 (permalink)
Thanks for the tips everybody - I went out and bought a trickle charger with all the plugs, lead wires, etc. so now I'll be able to keep battery charged from the right side of the bike by just removing the cover.
Battery Charging Woes dawgfan Twins Technical Talk 18 01-14-2007 03:25 PM
Battery or Charging system? OG-MOON Speed Triple Forum 6 12-24-2006 04:19 PM
Battery charging Caffeinated Twins Technical Talk 4 10-01-2006 07:01 PM
Battery charging gareth47 Hinckley Classic Triples 10 04-02-2004 02:20 PM
battery charging mah40 T3 Sport / Touring Forum 11 08-03-2003 09:04 AM
