» Log in
User Name Not a member yet?
Register Now!
Old 11-06-2005
cafetbird's Avatar
Cafe Racin' Moderator
Favorite Bike: 1996 Triumph Thunderbird
Other Motorcycle: 2002 Triumph Sprint ST
Extra Motorcycle: 1973 Triumph TR7RV
First thought on this thread - T300 classics are rock solid, very reliable motorcycles. However, being British, we know that they are expected to have a few "quirks" ;-) For folks considering one, keep these in mind:
1. Temperauture lights flicks on and off when the bike is NOT overheating. This is known to be a ground issue in the wiring harness.
2. Electrical system is known to overcharge the battery. Check the fluid level in your battery often to make sure it does not boil dry. Some also suspect that this leads to problems with the coils failing prematurely.
3. Coils - as stated in #2 - some bikes experience pre-mature coil failure. Some T-Birds were fitted with West German coils, but most bikes are fitted with coils manufactrured by Gill. Gill coils are less reliable. Nology makes coils that can be used as replacements, and are much more reliable.
4. Pressed nuts inside the silencers are known to break loose. It is best not to remove the brackets from the muffler unless absolutely necessary - instead, remove the bracket and muffler as an assembly.
5. 95 and early 96 models had an issue with a weak starter clutch. If you are considering one of these bikes, make sure it has been replaced.
This thread is for folks to list the know issues with the T300 classics line, in order to help out new owners of these bikes, and folks interested in purchasing one. All the on-line "experts", feel free to chime in with your experiences!
[ This message was edited by: cafetbird on 2006-05-21 06:26 ]
Scot Dail, IBA #31553
Pack Member, Charlotte RAT
Photo Album
Old 11-06-2005
Favorite Bike: 98 Thunderbird
A good idea for a thread Scott, but before we go making potential new owners paranoid, we should make it clear that not all of the problems are inevitable, or even likely.
A couple of other issues that come up regularly-
Sprag clutch failure. Before VIN # ??
Ditto The alternator impellor bolt shearing.
Old 11-06-2005
dhall10's Avatar
Favorite Bike: Vincent Black Shadow
Other Motorcycle: Yamaha Star Roadliner
Send a message via Yahoo to dhall10
In general for all the classic triples, Accessories are getting harder to find (Particularly the Late model Adventurers, '99-'01), no issues with getting repair parts yet tho'.
Dave Hall
My Photo Album
Bubbleheads and Bikes Forum
Old 11-06-2005
The "old" style alternator shaft bolt was used up to VIN 56684.
Don't about sprag clutch access, books only say later models.
Bob
My Photo Album
Old 11-06-2005
Oil breather system can be problematic. Make sure the oil level is absolutely right or the excess gets thrown into the airbox.
Even with correct level, the same thing can happen. I think it's down to the left hand cover oil seal and the slinger in the right side cover.
I have had problems with this - but to reinforce the point about not wanting to make potential buyers paranoid, I haven't had any other problems with my 99 T/bird. Great machine.
nil illegitimo carborundum
Old 11-06-2005
CDNTBS
Anyone buying a TBS should expect to swap out the seat for a more comfy model if they expect to do over 100 km per trip.
Steve
[ This message was edited by: MickMaguire on 2005-11-09 13:49 ]
Old 11-06-2005
Favorite Bike: '99 Legend
Just for the record. I have a 1999 Legend that runs great.
I have not (Knock on wood) had any of the issues listed above.
Mark
If it were easy, everybody would be doing it and we would all be out of a job!
Old 11-07-2005
Mark
Same for me.. :-D
Old 11-07-2005
Mark
Same for me.. :-D
And the same for me , Adventurer... :-D
Bob
My Photo Album
Old 11-07-2005
Rincewind's Avatar
Favorite Bike: Tiger 1050
I'm not an "on-line expert", but I'll throw in my two cents. First off, the bike has been great. It has style for miles, and for me is a very satisfying all-around bike.
Here is my list of issues:
1. Oil leaks due to overfilling. The amount prescribed in the manual is too much. It should be filled only to the midpoint on the sight glass. I forgot to specify this during my last service, so now I have a leaky bike again. The solution is to drain the oil to the proper level, which is midpoint in the sight glass, and to drain the airbox tube often until the excess oil has been run through. In 2003, the centrifigal oil distributor in the crankcase was replaced with a slightly different version under warranty, per Triumph central, but this hasn't seemed to make a difference.
2. I've also had the grounding issue with the instrument cluster, fixed under warranty with a new wiring harness.
3. My speedometer becomes erratic at times, despite the cable having been lubed.
4. My throttle cable snapped at only around 5,000 miles.
5. The horn sucks
Fuel Issues with Legend skeeter1949 Hinckley Classic Triples 8 04-30-2007 05:05 PM
T-bird/legend/adventurer ducstr Hinckley Classic Triples 1 11-06-2006 02:18 AM
TBS power from a Legend or Adventurer? bradc Hinckley Classic Triples 1 03-29-2006 10:24 AM
Adventurer vs Legend TT GerryP Hinckley Classic Triples 8 12-19-2005 09:47 AM
Legend or Adventurer??? Shades Hinckley Classic Triples 5 07-27-2004 09:21 AM
