Why stoping to ride in winter :razz: :razz: :razz: A good DIY chain rear and a rope front and show must go on..
BTW back to the topic, if you plan not to use your trumpet during winter time, and not invest in aa Optimate, you can remove the battery, store it in a dry an tempared room, and make a monthly small load ( 1 hour ) at less than 10% of the nominal capacity which is 14A on T3..
Keep in mind to keep the water level ok..
Of course do not forget to flush the carb, ( put the petcock on off).. Better to have the fuel tank full ( you can add some aditives), overinflate the tyres, all the basic things
[ This message was edited by: legend21 on 2005-11-05 15:27 ]
