Motorcycle.com
Old 11-04-2005   #11 (permalink)
On 2005-11-04 10:46, crosstie wrote:
<thread hijack>
At the risk of revealing my embarassing ignorance about motorcycle engines, what is 'carb synching' exactly?
</thread hijack>
Carb Synching is the process of adjusting the carburettors, so that each one allows the same volume of fuel/air mixture to enter the cylinders. It is essential for smooth operation and performance.
JWoodsie is offline   Reply With Quote
Old 11-04-2005   #12 (permalink)
Spooner's Avatar
Do you need to be a rocket scientist to do it?
S.P.O.O.N.E.R.
Huh?
Speedy MattHilda & Thunderasaki
Spooner is offline   Reply With Quote
Old 11-04-2005   #13 (permalink)
Nope its quite simple really if you have a good set of guages.
Old 11-04-2005   #14 (permalink)
Which means if you have the Morgan guages it is easy. :wink:
Morgan Carbtune Link!
[ This message was edited by: whodatpat on 2005-11-04 13:32 ]
Patrick http://www.click-smilies.de/sammlung...smiley-083.gif
"I'd rather have a bottle in front of me than a frontal labotomy."
whodatpat is offline   Reply With Quote
Old 11-04-2005   #15 (permalink)
jimmyj900's Avatar
A little more detail... Synching is adjusting the throttle butterflies so there's equal flow between the individual carbs and cylinders at an idle.
You do that by adjusting the butterfly positions and measuring the vacuum on the exit side of the carbs. When all three vacuums measure the same, the engine will idle at its smoothest.
It's an important part of setting up the idle and in part determines the smoothness at small throttle settings regardless of rpm.
Unless the synch is horribly off it has little effect over about 1/4 throttle.
Jim
CAUTION: This post may have been altered and critical safety information deleted without the permission or knowledge of the author.
Old 11-04-2005   #16 (permalink)
jimmyj900's Avatar
Well, since I'm no longer employed as a rocket scientist...
The center carb is the 'master' carb on the trple engines and the butterfly position is determined directly by the idle knob. For the other two carbs there are linkage adjustment screws on either side of the center carb.
The gauges connect via a rubber hose and pulsation damper to the take-off stubs at the rear of the carbs.
It's a pretty simple sequence. Connect the gauges, warm up the engine, set the idle, adjust the screws for equal vacuum and repeat the process until there's no longer need for adjustment.
It's helpful to check the balance between the vacuum gauges using 'T' connectors to hook all the gauges to a single carb. A four gauge set is good since if one gauge is off you can use the other three.
An auxilliary fuel tank with a valve and some extra fuel hose are convenient, but you can use the bike's fuel tank on a bench with some extra fuel line to supply fuel.
Jim
Old 11-04-2005   #17 (permalink)
Jim
Might I recomend making an external tank out of some hose and a soda bottle and a barbed nipple attached with the cap. Or buy a ready built one. The tank on the bench option is just begging to become a tank rolling around on the ground all scratched up option. :brk:
Luckily I droped the GS tank and not the TB tank.
Old 11-04-2005   #18 (permalink)
Cool, thanks for the replies all.
~Crosstie
'99 Speed Legend Retro Cafe Streetfighter
crosstie is offline   Reply With Quote
Old 11-05-2005   #19 (permalink)
Favorite Bike: Scrambler
johnyC's Avatar
Just a small addition to the other posts:
It's not essential to remove the tank and go rigging up a remote fuel supply, I do mine with the tank in place. The screw between the right and centre carb's is easily accessible, and I have a pet screwdriver that fits between the left and centre.
johny. the boy's happy, leave him alone.
johnyC is offline   Reply With Quote
Old 03-05-2006   #20 (permalink)
sethshady
I made one of these with a 3-way splitter at the bottom. worked like a charm:
http://www.powerchutes.com/manometer.asp
Cost about $5
Carb Synch Query... PaleForce Twins Talk 7 03-27-2007 08:34 PM
angled screwdriver for carb synch rshan Twins Technical Talk 14 08-28-2006 12:06 PM
Throttlebody synch BruceG Sprint Forum 5 04-20-2004 09:11 PM
Stutter/hesitates at low rpm, not in synch T3 Sport / Touring Forum 1 04-17-2004 10:16 AM
throttle body synch dangrass Sprint Forum 0 03-21-2004 01:22 PM
