T-bird Sport wont start after soaking rain - Triumph Forum: Triumph Rat Motorcycle Forums
Old 11-02-2005, 09:14 AM   #1 (permalink)
A friend of mine has a Thunderbird Sport. The bike sat out in the rain yesterday, and when he went to leave work, he had to fiddle with the ignition before the bike would start.
Today it won't start at all. With the key in park, he has lights, with the key in run he doesn't get any lights and the bike won't start.
He tried using a blower to dry things out, but that hasn't helped.
Any help/advise to get him back out on the road would be appreciated.
morecarl is offline   Reply With Quote
Old 11-02-2005, 10:15 AM   #2 (permalink)
Main Motorcycle: Mutato -- 2K Adventurer
jimmyj900's Avatar
The first thing to check on a Triumph with an electrical problem is the level of fluid in the battery. If the level is low, top it off with distilled water and put it on a charger for a while.
If you're getting a solenoid 'click' from under the front of the seat disconnect the battery leads, wire brush the leads and battery terminals until shiny and grease them to prevent corrosion or oxidation. If there's no solenoid click the switches are usually the problem.
High humidity, high temperatures and salt air can wreak havoc on an electrical system, so the first things I'd check are the clutch switch, the kickstand switch and the start switch. Look for sticking, but clean and grease them anyhow.
If that doesn't do it, let us know and we'll pursue it further.
Good luck!
Jim
Old 11-02-2005, 11:19 AM   #3 (permalink)
Administrator
Main Motorcycle: '04 Thunderbird Sport
Wombat's Avatar
Other Motorcycle: I wish!
With no light in the run position, it sounds to me like the ignition switch has gone belly up.
Bob
Click to see My Photo Album
Age is of no importance, unless you are a cheese.
Wombat is offline   Reply With Quote
Old 11-02-2005, 11:23 AM   #4 (permalink)
Main Motorcycle: Whatever I'm riding....
Other Motorcycle: 07 Tiger ABS & 79 T140
Extra Motorcycle: 95 TB & 08 Ducati S4RS
Spray WD-40 into the ignition lock to try to drive out the wet.
Chris
"Panniers can never hold everything you want, but they CAN hold everything you need."
parrycm is offline   Reply With Quote
Old 11-02-2005, 01:00 PM   #5 (permalink)
Main Motorcycle: Triumph
johnyC's Avatar
My TBS is occassionally reluctant to start because I have a dodgy clutch interlock switch. Try dabbing the clutch lever in and out as you push the start button and see if that makes any difference.
johny. the boy's happy, leave him alone.
johnyC is offline   Reply With Quote
Old 11-02-2005, 01:13 PM   #6 (permalink)
I'm guessing that the problem is with the ignition switch since the lights (headlight, diagnostic lights, etc.) aren't lighting up when he turns the key to 'Run', but the lights do turn on when he turns the key to 'Park'.
I don't believe the interlocks would prevent the lights from turning on, would they?
Old 11-02-2005, 01:36 PM   #7 (permalink)
There have been a couple/several TBS ignition switch failures reported on this forumn lately.
Have you tried the WD40 suggestion to drive the moisture out?
Good luck.
Bob
My Photo Album
bobshields55 is offline   Reply With Quote
Old 11-05-2005, 10:56 PM   #8 (permalink)
Main Motorcycle: TBS
my ignition switch got a bit sticky after riding in some rain showers.. put a little motor oil on the key and worked it into the switch. works great again. ( ignition switch on my old suzuki went out from weather, too.. had to replace it.)
aeycue is offline   Reply With Quote
Bike Wont start jimmydean Speed Triple Forum 5 08-28-2007 04:24 PM
Wont Start!! Classic, Vintage & Veteran 32 05-08-2005 11:18 AM
legend wont start yellowLEGEND Hinckley Classic Triples 7 03-18-2005 11:55 PM
New bike wont start... Triumph SuperSports 10 06-08-2004 10:27 AM
HELP. SPRINT ST WONT START Maintenance & Workshop Talk 6 03-28-2004 02:29 AM
