false neutrals - problem? - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 16 (permalink) Old 12-07-2011, 01:29 AM Thread Starter
Main Motorcycle: 2002 Thunderbird
deadman's Avatar
Hi everyone,
Not much to complain about, but I do seem to be finding the false neutrals a lot when I change down these days. Oil is only a few thousand kms old; new chain which maybe could be tighter, but is still correct to spec. Any ideas?
Hagon progressive springs; Ricor Intiminator fork valves; TBS rear shock absorber; Pingel fuel tap; Factory Pro jet kit; K&N in-box filter; drilled mufflers; AGM battery; Nology coils; Ignitech igniter; NGK Iridium plugs
deadman is offline
post #2 of 16 (permalink) Old 12-07-2011, 08:39 AM
Main Motorcycle: '99 Legend
BigAl8295's Avatar
Other Motorcycle: '98 TBS
Extra Motorcycle: 1969 Bridgestone 200
Send a message via Yahoo to BigAl8295
Did you check the oil level?
FCR-39 Carbs, Sprint Cams, British Customs Predator Exhaust, K&N Pod Filters, Nology Coils, Ignitech Ignitor, Progressive Fork Springs, ZX-6R shock, and one bad ass Horn Cover!
Charm City Mods vs Rockers Rally
BigAl8295 is offline
post #3 of 16 (permalink) Old 12-07-2011, 11:30 AM
Main Motorcycle: 99 Legend Sprint GT
IrlMike's Avatar
It's always said you have to be very positive with the shifter on these. I occasionally get a neutral between 4th & 5th but I think that's mostly short shifting quickly & not letting the shifter return fully. Otherwise its ok.
I guess I'd be looking at clutch operation & shifting technique (as well as Al's oil suggestion) before suspecting g'box problems?
I've heard that clutch plates can dry a little & revving the motor when warm with the clutch disengaged can ensure the plates are evenly soaked in oil helps.
98 Tbird tank/seat, Sprint fairing, ZX7R forks+Racetech Gold Valves, 08 ZX6R shock, short sw/arm, Alcon 6-pots, Ignitech+TPS, T'bike 3-1+Beowulf can, airbox/jet mods, tubeless wheel mod, lots :) per mile, 55mpg ave(imp)
IrlMike is offline
post #4 of 16 (permalink) Old 12-07-2011, 01:19 PM
Main Motorcycle: '96 Adventurer
ArferBrick's Avatar
Other Motorcycle: Yamaha TDR 125
I saw a kit advertised somewhere for our triples that dealt specifically with this issue. It had a stronger return spring I think.
Sadly I can't remember where I saw it now, it was somewhere online .
I hit the damn things now and then, but I'm getting better. I agree with Mike in that it's also a technique issue though. I believe I don't release the lever properly sometimes, unknowingly.
I've often been tempted to set the gear lever straight up, like we used to do with our trail bikes, so I can bang it forward and backward .
ArferBrick is offline
post #5 of 16 (permalink) Old 12-07-2011, 02:10 PM
Slinky's Avatar
Extra Motorcycle: I wish
I think it's mostly about technique. Sometimes I get a little sloppy and have to re-educate my foot. One likely problem is not letting the lever return fully to the centre position.
The boxes on these bikes are pretty tough.
Slinky is offline
post #6 of 16 (permalink) Old 12-07-2011, 03:41 PM
Main Motorcycle: Adventurer
Patchis's Avatar
Other Motorcycle: 1980 Kawasaki 750 Ltd
I have had my Adventurer for nearly a year now and have not once hit a false neutral, unlike my last bike (a 1100 Kawasaki). Mine is the 6 speed box though. Would that make any difference?
If it aint broke dont fix it
Patchis is offline
post #7 of 16 (permalink) Old 12-07-2011, 04:00 PM
Main Motorcycle: Kawasaki W800
Other Motorcycle: 1972 Suzuki Hustler
I've had 2 Tigers and 2 Sprints. They all had crappy gearboxes. My wife's 6 speed Thunderbird however, has a delightful gearbox, light, positive, and no false neutrals.
M.G.Vig is offline
post #8 of 16 (permalink) Old 12-07-2011, 04:14 PM
Slinky's Avatar
No, they all have six speed boxes. Triumph saw fit to remove one of the sixth gears and replace it with a spacer for some bizarre reason. They also fitted a 5 speed selector drum instead of the 6 speed one.
Slinky is offline
post #9 of 16 (permalink) Old 12-07-2011, 06:47 PM
Main Motorcycle: 2000 Adventurer
eelmgren's Avatar
I get a false neutral occasionally between 4th & 5th. Never given it much thought - figured it was just sloppy shifting on my part. Each time it happens, I mentally remind myself to be firm on my up-shifts
eelmgren is offline
post #10 of 16 (permalink) Old 12-07-2011, 10:58 PM
Main Motorcycle: 1996 Thunderbird
BRG-BIRD's Avatar
Other Motorcycle: 2000 Sprint ST
Factory Pro Tuning
"You are either on something or onto something"........The Common Man
BRG-BIRD is online now
False Neutrals Dog Trainer Air Cooled Twins Technical Talk 7 11-04-2009 06:12 PM
False Neutrals & Shifting Gear Problem scobell Speed Triple Forum 15 10-14-2007 05:07 PM
Anyone get false neutrals riron2001 Air Cooled Twins Technical Talk 13 07-13-2007 06:23 PM
False Neutrals? xsubsalior Air Cooled Twins Technical Talk 12 10-17-2006 09:01 PM
false neutrals 97TB Speed Triple Forum 5 10-27-2004 02:27 PM
