BikeBanditMotorcycle.comAdvanstarMotorcycleShows
ShopTriumph.com
Old 10-24-2005   #1 (permalink)
Rothonbird
Hi everyone out there in Trumpet land. I've just bought my dream bike - Ok I've had faster, slicker and my mates think I'm an old codger but my Maroon and cream sparkling 2,800 miles immaculate 97 T bird is the bike I've been waiting for. I've never had a Triumph before - What do I need to know about my Tbird before it goes wrong - can anyone help?
Old 10-24-2005   #2 (permalink)
Rev it up to 2500rpm, put on your high beams, and then step on your rear brake lever. If you hear a funny noise around your alternator, check the alternator bolt.
robtroll23 is offline   Reply With Quote
Old 10-24-2005   #3 (permalink)
Hello and welcome Rothonbird
- Check the battery acid level regularly, the alternators are fierce on our T3s.
- Do, or have done, the valve shim adjustment check. The Triumph schedule calls for it to be done at 12000 mile intervals. I recommend doing yours now or over the winter, because of the age. I did that with mine, age vs. mileage, and was pleased with the result.
- Flush and replace the coolant, it is often overlooked.
- Enjoy your dream bike.
:-D :-D
[ This message was edited by: bobshields55 on 2005-10-24 19:20 ]
Bob
My Photo Album
bobshields55 is offline   Reply With Quote
Old 10-24-2005   #4 (permalink)
ladybird95
not sure what year they fixed the paint problem, but early t-birds have a problem with paint that was applied inside the filler opening on the tank.
i still have not fixed mine, but what is happening is the paint is bubbling off where gas touches it, with the chance it may drop into the tank and either hopefully clog your fuel system, or worse make its way into your engine.
just take the fuel cap off, and look in, you will instantly know if you have a problem.
Old 10-24-2005   #5 (permalink)
Age does not affect the valve clearance at all :hammer: mileage yes
check has to be made at the 1st 6000 miles service, can be done eaelier, but not to much. Then valve check has to be done every 6000. 12000 is an usual intrevall for shimm changes ( if needed).
Due to the age and low mileage of your bike, I will recomand to check the tank ( rust for example), the carb , all the rubber hoses, including the intake manifoilds, the lubricant ,the coolant and the brake and clutch fluid .
The air filter is an issue too. The OEM foam element itself is not available as a spare part. Don't think that you can afford to make the task within an hour for the 1st time :hammer:
legend21 is offline   Reply With Quote
Old 10-24-2005   #6 (permalink)
That may be so about the age not affecting the shims, but I had mine checked at 4000 miles and adjustment (though minor) was needed, and performance increased noteably.
Bob
My Photo Album
Old 10-24-2005   #7 (permalink)
The valves take their place within their first thousands miles..
I've to change 8 shims at 5000 too ...
However this is linked to mileage not to age ... and is not the most critical point on a 8 years bike with such a low mileage ..
basicaly I recomand to be carefull with an old but low miled bike.. It depends of the quality of the storage and if the maintenance schedules have been respected ..
( old wet oil, dry seals , rusted brake callipers )etc...
Old 10-24-2005   #8 (permalink)
Your message is loud and clear and understood. I even agree with it! Must it be continually reposted?
[ This message was edited by: bobshields55 on 2005-10-24 21:00 ]
Bob
My Photo Album
Old 10-24-2005   #9 (permalink)
jimmyj900's Avatar
The easy way to get rid of that flaking paint is to stick some duct tape to it an pull off the tape. The loose paint will come with it.
Jim
http://s279.photobucket.com/albums/k...0Head%20Stuff/
Old 10-25-2005   #10 (permalink)
Jimmy, I have the same problem on my tank as well, will duct tape really do the job?
Should I seal the tank with anything after that?
And does the peeling paint spread to the outside of the tank?
This is encouraging news for me !! I thought I had to get the entire tank repainted.
joe
1995 thunderbird, tiger cams, TOR pipes
1978 Yamaha 650 special
1983 Suzuki gs550
1979 WR250 Husqvarna, 1972 Honda MR50
walshja is offline   Reply With Quote
tbird sport carb rubbers for tbird & legend Spooner Hinckley Classic Triples 14 08-11-2005 01:45 AM
need help with 98 tbird Modifications & Workshop Talk 1 06-17-2005 03:05 AM
Swap parts from 98 Tbird to 02 Tbird Hinckley Classic Triples 3 06-16-2005 11:08 AM
can a newer tbird 6 speed be put on a 98 tbird? 00wabbit Hinckley Classic Triples 17 03-30-2005 09:18 PM
where you can get these for a Tbird ? Hinckley Classic Triples 4 03-09-2005 04:44 PM
